Further efforts show that the distance upload is giving the correct value. I had the wrong flag checked (not as clear as it might be in the GUI). The other issues remain. But at least I CAN get useful analysis results.
Michael
On May 23, 2012, at 4:49 PM, <grass-dev-request@lists.osgeo.org>
wrote:
Send grass-dev mailing list submissions to
grass-dev@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
grass-dev Info Page
or, via email, send a message with subject or body ‘help’ to
grass-dev-request@lists.osgeo.orgYou can reach the person managing the list at
grass-dev-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-dev digest…”
Today’s Topics:
- broken stuff in vector modules (Michael Barton)
- another bug in v.distance (Michael Barton)
- v.distance values bogus in GRASS 6.4.2 also (Michael Barton)
Subject: [GRASS-dev] broken stuff in vector modules
Date: May 23, 2012 4:43:11 PM GMT+02:00
To: GRASS developers grass-developers grass-dev@lists.osgeo.org
I don’t use the vector modules a lot and so they don’t get a lot of testing from me. I’m trying to do a project with someone that uses vector module and I find that some key things are broken. The following apply to GRASS 7 and GRASS 6.4.3.
v.distance gives bogus results for point to line distance uploads in a latlon region. For example, the distance uploaded from one site point to the nearest waterway is 5767967.05475, yet measuring this with the distance tool gives a much more reasonable 33211 m. The uploaded distance is off by an order of 173X – an enormous error. Nothing in the docs says that you cannot use v.distance with latlon regions.
To get around this, I thought I’d try to get the length of the line that connects each site point with its nearest waterway (a v.distance option). But when I tried to make a new table for this in the table manager, I find that I cannot access the “table description” section of the “manage layers” page in the attribute table manager. This is again because wx.StaticBox needs to be defined in a particular order or the Mac interface cannot access it. This has been a recurrent problem with wx.StaticBox. The StaticBox must be instantiated before any of its contents.
After creating a linked table using v.db.addtable instead of the attribute manager, I tried to modify the layer in the attribute table manager, but only received a message that “ is not a valid value”. Another bug.
I did manage to get a length value into the lines connecting the points and they are quite reasonable values. But of course I have no way that I can see to link the distance lines back to the points from which they were created with v.distance. So I still don’t have analysis results and my colleague is ready to try this in ArcGIS.
Any suggestion for a workaround would be much appreciated. And of course, the multiple bugs here need to be fixed.
Michael
C. Michael Barton
Visiting Scientist, Integrated Science Program
National Center for Atmospheric Research &
University Consortium for Atmospheric Research
303-497-2889 (voice)Director, Center for Social Dynamics & Complexity
Arizona State University
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.eduFrom: Michael Barton Michael.Barton@asu.edu
Subject: [GRASS-dev] another bug in v.distance
Date: May 23, 2012 4:47:08 PM GMT+02:00
Forgot to mention that the table selection pull-downs do not work in any version of the v.distance GUI–from 6.4.2 to 7.0
Michael
C. Michael Barton
Subject: [GRASS-dev] v.distance values bogus in GRASS 6.4.2 also
Date: May 23, 2012 4:48:37 PM GMT+02:00
So the values for point to line distances are just as bad in GRASS 6.4.2 as they are in GRASS 7. Any suggestions on how to get this information for a latlon region?
Michael
C. Michael Barton
grass-dev Info Page
C. Michael Barton
