Markus Neteler via RT wrote:
https://intevation.de/rt/webrt?serial_num=2793
Apparently Vect_point_on_line() lacks support for side offset. Indeed,
it doesn't even have such a parameter.
We can now either remove all the side_offset stuff from the manual
page or convince a developer to expand Vect_point_on_line(). The
functions used in v.buffer/v.parallel might be helpful in this regard.
Vect_point_on_line() is fine, the adjustment should come just after:
ret = Vect_point_on_line ( LPoints, offset1, &x, &y, &z, &angle, NULL);
/* Should Vect_point_on_line be passed the side offset here? */
/*** (YES) ***/
if(side_offset != 0.0) better? if(fabs(side_offset) > 0.0)
shift_point_90(&x, &y, side_offset, angle);
Vect_append_point ( SPoints, x, y, z );
if we know the slope of the line at the point (angle*), it is easy
enough to calculate a point perpendicular to it (in the x,y plane)
offset by a certain distance with a little trig.
*angle - pointer to angle of line in that point (radians,
counter clockwise from x axis) or NULL
with luck the line direction is ok- shift off to the left or right?
can anyone compose a nicer example for the v.segment help page?
(v.to.points -n or -v to get points?)
or is <side offset> for a threshold? (I'm not really sure how v.segment
is supposed to work)
For 6.2 we should <!-- comment out --> the references to it in the help
page.
Hamish
