Markus,
As you have just fixed one parser error in the v.to.db, do you mind if I
trigger your attention to another long-standing one?
If all the valid 'options', or specific combinations of them, are listed in a
row, v.to.db accepts it *if they come in the same order as the are listed in
the Description*.
spearfish60
For example - this works while it should not:
$ v.to.db -p map=landuse
option=cat,area,compact,perimeter,length,count,coor,start,end,sides,query
type=centroid col=col1
8 categories read from map
0 records selected from table
0 categories read from map exist in selection from table
0 categories read from map don't exist in selection from table
0 records updated/inserted
0 update/insert errors
I can remove an option from the end of the comma-separated list and from the
beginnig, and this will still work:
option=area,compact,perimeter,length,count,coor,start,end,sides type=centroid
col=col1
And this too:
v.to.db -p map=landuse option=perimeter,length,count,coor type=centroid col=col1
But if I take out one somewhere in the middle *so that the order they are
listed in Description IS NOT PRESERVED*, v.to.db returns an error like it should:
$ v.to.db -p map=landuse option=perimeter,length,coor type=centroid col=col1
Error: value <perimeter,length,coor> out of range for parameter <option>
Legal range:
Maciek
