Hi
Hi, I'm using r.thin command, and it seems that it changes Nodata value
cells of the original raster (surrounding cells obtained after the
gereference operation of à scanned map) to the value 1
Could you put screenshots that explain your problem (and the input and
problematic output data if possible) somewhere? What was your r.thin syntax
exactly?
What Grass version? Platform?
Does soemone already had this problem,
I haven't, I think.
is it possible to change nodata value to 0 for example
r.null?
Maciek
