[GRASS-dev] [bug #4794] (grass) r.thin
r.thin works (in GRASS 6.1-CVS). Quick test:
GRASS 6.1.cvs (spearfish60): > g.region -dp
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928010
south: 4913700
west: 589980
east: 609000
nsres: 30
ewres: 30
rows: 477
cols: 634
r.thin fields out=fields_skeleton
File fields -- 477 rows X 634 columns
Bounding box: l = 3, r = 635, t = 2, b = 468
   Pass number 1
        Deleted 5632 pixels
   Pass number 2
   Pass number 81
        Deleted 0 pixels
Thinning completed successfully.
Output file 477 rows X 634 columns
Window 477 rows X 634 columns
d.mon x0
d.rast fields_skeleton
# -> looks ok, no data are present
r.univar fields_skeleton
100%
total null and non-null cells: 302418
total null cells: 299926 <-- no data are there !
Of the non-null cells:
n: 2492
minimum: 1
maximum: 63
range: 62
mean: 44.7364
standard deviation: 21.6878
variance: 470.363
variation coefficient: 48.4792 %
sum: 111483
I suspect that the original map doesn't have NULL where
you think they should be. You can verify it with d.what.rast.
I don't see a problem in r.thin (note that we fixed it in
April):
2006-04-04 17:07 markus
        * main.c: increased to 200 iterations default
2006-04-04 17:06 markus
        * thin_lines.c: fixed max iterations
2006-04-04 16:48 markus
        * local_proto.h, main.c, thin_lines.c: added iterations parameter.
        Added exit error message if failure. Fixed wording. Increased
        default iterations
