this bug's URL: http://intevation.de/rt/webrt?serial_num=5060
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C6CAB2.EB6B47C6
Content-Type: text/plain
Attached is some improved documentation for v.out.ascii. I've included
information on what the Grass 'standard' format is, largel based on the
description given in v.in.ascii. I've also included an example showing what
the 'standard' output looks like on the 'quads' vector in Spearfish.
Let me know if in the future you prefer the documentation improvements to be
attached as a diff file, or pasted within the email text itself.
~ Eric.
Content-Type: application/octet-stream;
name="v.out.ascii.diff"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="v.out.ascii.diff"
--- v.out.ascii.html 2006-08-28 11:55:18.000000000 -0300=0A=
+++ v.out.ascii_improved.html 2006-08-28 11:54:56.000000000 -0300=0A=
@@ -61,6 +61,20 @@=0A=
vector files between GRASS and other software, and for transferring =
data =0A=
between machines.=0A=
=0A=
+<p>=0A=
+If the <b>format</b> parameter is set to <b>standard</b>, a GRASS =
ASCII vector file will be exported, which may contain a mix of =
primitives including points, lines, boundaries, centroids, areas, =
faces, and kernels. A header will be written to the output ascii file =
containing vector metadata, if such metadata exists.=0A=
+<p>=0A=
+The primitive codes are as follows:=0A=
+<UL>=0A=
+<LI>'P': point</LI>=0A=
+<LI>'L': line</LI>=0A=
+<LI>'B': boundary</LI>=0A=
+<LI>'C': centroid</LI>=0A=
+<LI>'F': face (3D boundary)</LI>=0A=
+<LI>'K': kernel (3D centroid)</LI>=0A=
+<LI>'A': area (boundary) - better use 'B'; kept only for backward =
compatibility</LI>=0A=
+</UL>=0A=
+The coordinates are listed following the initial line containing the =
primitive code, the total number of vectors in the series, and the =
number of categories (1 for a single layer, higher for multiple =
layers). Below that 1 or several lines follow to indicate the layer =
number and the category number (ID).=0A=
<p> =0A=
The order of coordinates for new (standard) version of ASCII file is =
<BR><BR>=0A=
X Y [Z]=0A=
@@ -90,6 +104,47 @@=0A=
<em>v.to.points</em> and then exporting with <em>v.out.ascii</em> in =
=0A=
<em>points</em> mode.=0A=
=0A=
+<h2>EXAMPLE</h2>=0A=
+=0A=
+<h3>Example 1) - export to standard mode</h3>=0A=
+Sample ASCII polygon vector map output for 'standard' mode. =0A=
+The example can be tested in the Spearfish sample dataset:=0A=
+<p>=0A=
+<div class=3D"code"><pre>=0A=
+v.out.ascii input=3Dquads format=3Dstandard=0A=
+</pre></div>=0A=
+<p>=0A=
+ORGANIZATION: US Army Const. Eng. Rsch. Lab=0A=
+DIGIT DATE: May 1987=0A=
+DIGIT NAME: grass=0A=
+MAP NAME: Quads=0A=
+MAP DATE: May 1987=0A=
+MAP SCALE: 24000=0A=
+OTHER INFO:=0A=
+ZONE: 13=0A=
+MAP THRESH: 18.288000=0A=
+VERTI:=0A=
+B 4=0A=
+ 599587.1820962 4914067.53414294=0A=
+ 589639.15126831 4913922.5687301=0A=
+ 589440.96838162 4927803.62500018=0A=
+ 599375.87959179 4927959.83330436=0A=
+B 2=0A=
+B 4=0A=
+ 609541.5508239 4914236.0597482=0A=
+ 609316.10665227 4928116.8490555=0A=
+C 1 1=0A=
+ 594125.63 4921115.58=0A=
+ 1 1=0A=
+C 1 1=0A=
+ 604433.84 4921087.1=0A=
+ 1 2=0A=
+</pre></div>=0A=
=0A=
<h2>SEE ALSO</h2>=0A=
=0A=
------_=_NextPart_000_01C6CAB2.EB6B47C6--
--- Headers Follow ---
From epatton@nrcan.gc.ca Mon Aug 28 17:11:49 2006
Return-Path: <epatton@nrcan.gc.ca>
Delivered-To: grass-bugs@lists.intevation.de
Received: from kolab.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 9F01D1005C5
for <grass-bugs@lists.intevation.de>; Mon, 28 Aug 2006 17:11:49 +0200 (CEST)
Received: from localhost (localhost.localdomain [127.0.0.1])
by kolab.intevation.de (Postfix) with ESMTP id 7717B10C3FB
by kolab.intevation.de (Postfix) with ESMTP id 37AA310C44E
Received: from s5-dar-r1.nrn.nrcan.gc.ca (unknown [192.55.224.2])
by kolab.intevation.de (Postfix) with ESMTP id 1E1DB10C3FB
for <grass-bugs@intevation.de>; Mon, 28 Aug 2006 17:11:47 +0200 (CEST)
Received: by s5-dar-r1.nrn.nrcan.gc.ca with Internet Mail Service (5.5.2657.72)
id <RG7NW8NA>; Mon, 28 Aug 2006 12:11:43 -0300
Message-ID: <0E5A77B55A57D511BB3F0002A537C26208C55B3D@s5-dar-r1.nrn.nrcan.gc.ca>
To: "'grass-bugs@intevation.de '" <grass-bugs@intevation.de>
Cc: "'tutey@o2.pl '" <tutey@o2.pl>
Subject: v.out.ascii: Improved documentation
Date: Mon, 28 Aug 2006 12:11:42 -0300
MIME-Version: 1.0
X-Mailer: Internet Mail Service (5.5.2657.72)
Content-Type: multipart/mixed;
boundary="----_=_NextPart_000_01C6CAB2.EB6B47C6"
X-Virus-Scanned: by amavisd-new at intevation.de
X-Spam-Status: No, hits=-2.279 tagged_above=-999 required=3 tests=[AWL=-1.279,
BAYES_20=-1]
X-Spam-Level:
