[GRASS-dev] [bug #5206] (grass) r.out.tiff: '/' in 'output' triggers a false warning
this bug's URL: http://intevation.de/rt/webrt?serial_num=5206
Subject: r.out.tiff: '/' in 'output' triggers a false warning
Wanted to export a tiff into my 'tmp' dir:
$ r.out.tiff -t input=map output=tmp/map
I got a warning:
"Illegal filename. character </> not allowed."
but the export proceeded, and the tif&tfw were stored in the 'tmp' dir as
requested.
Interestingly, it will work only if '-t' is used.
Should the warning be removed?
Maciek
