rez@touchofmadness.com wrote (Tue, Nov 28 2006 15:52:07):
The problem is with db_append_string(). I just committed a patch that
handles memory properly before the call, but I don't know if it will be
of any help. Give it a try.
Brad,
Thanks, but it didn't help, as you suspected. Still the same segfault. I'm
getting it on my 2 machines:
Ubuntu Breezy 32bit AMD Athlon (Barton), 2.6.12-10-k7, gcc 3.4.4
Ubuntu Dapper 32bit Pentium M (Dothan), 2.6.15-27-686, gcc 4.0.3
You wrote you are using 64bit, same as Markus, who also can't reproduce the
segfault. Is there anybody on 32bit who can?
Maciek
