[GRASS-dev] [bug #5481] (grass) BFD 2.16.91.0.7 20060317 internal error, aborting at elfcode.h
this bug's URL: http://intevation.de/rt/webrt?serial_num=5481
Subject: BFD 2.16.91.0.7 20060317 internal error, aborting at elfcode.h
Platform: GNU/Linux/x86_64
grass obtained from: Trento Italy site
GRASS Version: grass 6.2.1 (2006)
I've got this message in a make >& make.out
gcc -shared -o /usr/local/src/grass-6.2.1/dist./lib/libgrass_gproj.6.2.1.so -L/usr/local/src/grass-6.2.1/dist./lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/src/grass-6.2.1/dist./lib OBJ./get_proj.o OBJ./do_proj.o OBJ./convert.o OBJ./datum.o OBJ./ellipse.o -lgrass_gis -lgrass_datetime -lz -lproj -L/usr/lib64 -lgdal && if [ -z "" ] ; then ln -f -s libgrass_gproj.6.2.1.so /usr/local/src/grass-6.2.1/dist./lib/libgrass_gproj.so; fi
/usr/bin/ld: BFD 2.16.91.0.7 20060317 internal error, aborting at elfcode.h line 190 in bfd_elf64_swap_symbol_in
/usr/bin/ld: Please report this bug.
collect2: ld returned 1 exit status
make[2]: *** [/usr/local/src/grass-6.2.1/dist./lib/libgrass_gproj.6.2.1.so] Error 1
make[2]: se sale del directorio `/usr/local/src/grass-6.2.1/lib/proj
I configured with ./configure --prefix=/usr/local --enable-64bit --with-postgres-includes=/usr/include/pgsql --enable-shared
Anyway, I've could compile GRASS, but with I push enter button in the splash-project window a child killed segmentation violation it's produced (the console still go on, with some commands).
I wish this can be helpful for you. Best Regards,
Miriam
This is an error in "ld" (the linker, from the "binutils" package). It
should be reported to the binutils maintainers, or to the maintainers
of your OS distribution. There isn't anything which the GRASS
developers can do about it.
