Hi!
I have found checkbashisms script. In Debian and alike it's provided with
devscripts package. Version 2.9.10 run on GRASS scripts from 6.3 CVS
18.03.2007 yields following warnings. I'm no expert and can't say which are
real. Just letting others know.
$ grass63
$ for i in `ls /usr/local/grass-6.3.cvs/scripts/`; do checkbashisms
/usr/local/grass-6.3.cvs/scripts/$i; done
possible bashism in /usr/local/grass-6.3.cvs/scripts/d.correlate line 75: '[
"$name" == '
possible bashism in /usr/local/grass-6.3.cvs/scripts/d.correlate line 81: '[
"$ok" == '
possible bashism in /usr/local/grass-6.3.cvs/scripts/d.polar line 137: '[
$TOTALVALIDNUMBER == '
possible bashism in /usr/local/grass-6.3.cvs/scripts/g.mlist line 118: '[
"$itype" == '
possible bashism in /usr/local/grass-6.3.cvs/scripts/i.in.spotvgt line 200:
'${NAME}_$PID,${NAME}'
script /usr/local/grass-6.3.cvs/scripts/r.tileset is already a bash script;
skipping
possible bashism in /usr/local/grass-6.3.cvs/scripts/r.univar.sh line 116:
'function abs'
possible bashism in /usr/local/grass-6.3.cvs/scripts/v.univar.sh line 147:
'function abs'
Maciek
On 3/18/07, Maciek Sieczka via RT <grass-bugs@intevation.de> wrote:
Hi!
Hi Maciek.
$ grass63
"$name" == '
"$ok" == '
"$itype" == '
Those are done, and on CVS.
This is a false positive, it is an argument to g.rename
skipping
'function abs'
'function abs'
Those are false positives; the functions are defined within inlined awk scripts.
Maciek
grass-dev mailing list
grass-dev@grass.itc.it
-- Daniel Calvelo Aros
