On Feb 27, 2008, at 5:30 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Wed, 27 Feb 2008 11:58:58 +0100
Subject: [GRASS-dev] Build winGRASS with Python and wxPython
To: <grass-dev@lists.osgeo.org>
Message-ID: <FBCMMO02t4SPh1qHxpE0002f966@FBCMMO02.fbc.local>
Content-Type: text/plain; charset="iso-8859-1"Hi all,
I installed prebuilt binaries of Python 2.5.2 and wxPython2.8 (unicode-2.8.7.1-py25); GRASS configure help tells to specify python and wxpython config files... but I don't have those files! any suggestions?
There is a separate dev Windows package that you need to instal for wx-config. This has been a confusing issue for many of us. There is a dev package for Linux that is part of the normal group of installations that you can install or not. The same files are installed automatically in the Mac binary, but put in a different place than Linux puts them. I saw a link for a Windows dev package on the binary downloads page for wxPython and suppose that this where you get these files for Windows--though I don't know where Windows will put them.
That said, you don't need to install this unless you want to try to compile the new in-development digitizer. Most people are still having difficulty compiling this and I know that Martin is actively working on it. It would certainly be helpful to him if you wanted to try compiling the digitizer in Windows--but this isn't necessary to run the rest of the wxPython GUI.
I also had a problem trying to enable python in GDAL, because the distributed Windows installer of Python is built using Visual Studio, while GDAL (if built with MinGW) requires a MinGW built version of Python; this means that, if you want to enable Python bindings in GDAL, you'll need to build Python from source using MinGW.
You don't need to enable Python in GDAL to use the wxPython GUI. But perhaps you are trying to enable Python in GDAL for other reasons?
Michael
I hope that it will be not the same even in GRASS!
Thanks
Marco
