[GRASS-dev] Building GRASS packages from tarball on Launchpad
Hi Sebastiaan,
2015-02-13 15:37 GMT+01:00 Sebastiaan Couwenberg <sebastic@xs4all.nl>:
The upstream branch only contains the upstream source imported from the
tarball, the debian directory is maintained on the master & experimental
branches.
Currently the master branch is used for GRASS 6.4 which is included in
the Debian sid & jessie. The experimental branch is used for GRASS 7.
thanks for explanation.
I suggest you create new branches under the grass/ prefix where you can
maintain the packaging for the grass70 & grass71 source packages
including in the GRASS PPA on Launchpad.
You can use a branch for each source package, i.e. grass/7.0 &
grass/7.1. If want to track the upstream development I suggest to use
the grass/upstream branch synced with the bzr repo using git-bzr(1).
OK.
Martin
PS: BTW, I applied your patch [1] in GRASS trunk (r64606) and relbr70 (r64607).
[1] http://anonscm.debian.org/cgit/pkg-grass/grass.git/tree/debian/patches/allows-to-typo.patch?h=experimental
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
2015-02-13 16:39 GMT+01:00 Sebastiaan Couwenberg <sebastic@xs4all.nl>:
Thanks, I've marked the patch as Applied-Upstream :slight_smile:
please mark in the same way
http://anonscm.debian.org/cgit/pkg-grass/grass.git/tree/debian/patches/www-browser?h=experimental
Martin Landa
2015-02-13 17:01 GMT+01:00 Sebastiaan Couwenberg <sebastic@xs4all.nl>:
Thanks for applying the patch, I've also marked the www-browser patch as
Applied-Upstream:
http://anonscm.debian.org/cgit/pkg-grass/grass.git/commit/?h=experimental&id=9349bac06629531e2b504b50d76f999d813441c0
you can also mark
http://anonscm.debian.org/cgit/pkg-grass/grass.git/tree/debian/patches/wxpy3.0-compat.patch?h=experimental
(see r64610:1)
Martin
Martin Landa
2015-02-13 17:24 GMT+01:00 Sebastiaan Couwenberg <sebastic@xs4all.nl>:
regarding
http://anonscm.debian.org/cgit/pkg-grass/grass.git/tree/debian/patches/check4dev?h=experimental
I would suggest to close it as 'wontfix', `dpkg-query` will not work
on Fedora and other non-debian distributions.
I have added extra check some time ago to `g.extension` which should
work on all supported platforms [1].
Martin
[1] http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/scripts/g.extension/g.extension.py?rev=64581#L786
Martin Landa
2015-02-13 17:57 GMT+01:00 Sebastiaan Couwenberg <sebastic@xs4all.nl>:
We could drop this patch from the Debian package or keep carrying it as
it won't be hard to maintain.
I think we could drop this patch, bearing in mind that g.extension
already checks if Module.make exists. Just 2 cents, Martin
Martin Landa
2015-02-13 18:09 GMT+01:00 Sebastiaan Couwenberg <sebastic@xs4all.nl>:
To reduce the diff with upstream I opted to drop the check4dev patch and
rely on your check instead.
thanks.
Any thoughts about the pager patch? I think it could be merged upstream
too, but it's as a bit distribution specific.
probably yes, see "patches from http://anonscm.debian.org/cgit/
(makefile/ctypes)" thread.
Martin
Martin Landa
2015-02-13 14:57 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
I contacted Launchpad Support [1]. Thanks, Martin
[1] https://answers.launchpad.net/launchpad/+question/262058
the source of problem is probably missing OpenPGP in my Launchpad
account. Will re-try on Monday again.
Martin
Martin Landa
