[GRASS-dev] Building GRASS packages from tarball on Launchpad
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi, here are my short notes on building GRASS packages from tarball on
Launchpad (opposite to daily builds done by regular fetching of SVN).
Following work flow can be used for building release builds such as
RCs or final release versions which require to build exact version. I
hope this can help.
# Download latest existing version of package from Launchpad
$ dget
https://launchpad.net/~grass/+archive/ubuntu/grass-stable/+files/grass70_7.0.0RC1-3~ubuntu12.04.1.dsc
# Prepare working directory with git enabled
$ mkdir pkg-grass
$ cd pkg-grass
$ git init
# Import downloaded version of package from Launchpad
$ git-import-dsc ../grass70_7.0.0RC1-3%7Eubuntu12.04.1.dsc
# Import new tarball we want to build
$ git-import-orig ../grass_7.0.0~RC2.tar.gz
# Optionally, merge Debian packaging (content of debian direcory:
branch lp:~grass/grass/grass_trunk_debian) here
# Update Debian changelog
$ dch -i
$ git diff
index e05cf9b..30e282c 100644
- --- a/debian/changelog
+++ b/debian/changelog
@@ -1,3 +1,9 @@
+grass70 (7.0.0~RC2-1~precise1) precise; urgency=medium
+ * Verifying build workflow - not a real build
+ -- Ivan Mincik <ivan.mincik@gmail.com> Mon, 26 Jan 2015 00:03:08 +0100
$ git add debian/changelog
$ git ci -m "Debian changelog update"
# Prepare source upload
$ git-buildpackage --git-debian-branch=master --git-builder="debuild
- -S -sa"
# Upload source package for build to Launchpad
$ dput ppa:imincik/gis-exp
../build-area/grass70_7.0.0~RC2-1~precise1_source.changes
See:
* http://pkg-grass.alioth.debian.org/policy/
Tools to use:
* git-buildpackage, pbuilder
My configuration files:
* https://gist.github.com/imincik/6bd3d5df52318801d135
Ivan Minčík
ivan.mincik@gmail.com GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik@gista.sk GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJUxX7iAAoJEPfdLsR5UpoeQR8H/RzdUU2E4trF9vPTsJP/vU9f
3aLJn0eqrbqmsSVFMImDugIzZMvp8FUghftLzWF7CLt2WRAaZiOT5hfVXb0AA4mq
5L1TYD/IXOHdVwxTWenFsG7matwm39f2fFj9xLKXpJkz/esRkcXD1Cc2HsWt7nne
U+suAoIPKQAigYvt86WdZ0QJ9HWBrSymqi2Vff+B2aGCjMC8+vc7ruXp49fZ6Uv/
BgmAbyXwHLCK7BP1OVCxev4S5mwdHX8ErwUzh5rbLetCkMBKCKaukgUtayF0n//K
wpwnjz+8pe8PgZSi773cIt/NiW3N7g4JZhllgPbXGXRSrQaPLtP9pyxsr/f1I20=
=RLgu
-----END PGP SIGNATURE-----
Hi Ivan,
2015-01-26 0:40 GMT+01:00 Ivan Mincik <ivan.mincik@gmail.com>:
thanks a lot for your extremely important notes! Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
Hi Ivan,
I started building my workflow for packaging on Launchpad based on your notes.
$ dch -i
I ended up here with
dch: fatal error at line 580:
Cannot find debian/changelog anywhere!
Are you in the source code tree?
(You could use --create if you wish to create this file.)
Do you have any idea what could be wrong here? Thanks in advance! Martin
Martin Landa
2015-02-09 13:46 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
$ dch -i
I solved that by
bzr branch lp:~grass/grass/grass70_release_debian debian
Sorry for the noise. Martin
Martin Landa
Hi Ivan,
2015-02-09 23:03 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
I solved that by
unfortunately another problems appeared
$ git-buildpackage --git-debian-branch=master --git-builder="debuild -S -sa"
gbp:error: You have uncommitted changes in your source tree:
gbp:error: On branch master
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        debian/.bzr/
        debian/README.Debian
        debian/README.RunningWithoutGUI
        debian/README.source
nothing added to commit but untracked files present (use "git add" to track)
gbp:error: Use --git-ignore-new to ignore.
OK, I tried
-S -sa" --git-ignore-new
but it failed with
dpkg-buildpackage -rfakeroot -d -us -uc -S -sa
dpkg-buildpackage: source package grass70
dpkg-buildpackage: source version 7.0-1~svn55286~ubuntu2
dpkg-buildpackage: source distribution quantal
dpkg-buildpackage: source changed by Rashad M <mohammedrashadkm@gmail.com>
dpkg-source --before-build pkg-grass
dpkg-source: info: using options from pkg-grass/debian/source/options:
--extend-diff-ignore=(^|/)(config\.sub|config\.guess|mswindows/osgeo4w/grass.tmpl|config.log)$
fakeroot debian/rules clean
debian/rules:30: /usr/share/dpatch/dpatch.make: No such file or directory
make: *** No rule to make target '/usr/share/dpatch/dpatch.make'. Stop.
dpkg-buildpackage: error: fakeroot debian/rules clean gave error exit status 2
debuild: fatal error at line 1376:
dpkg-buildpackage -rfakeroot -d -us -uc -S -sa failed
gbp:error: 'debuild -S -sa' failed: it exited with 29
Sorry for bothering you, do you have any idea how to solve this?
Thanks a lot! Martin
Martin Landa
Hash: SHA1
On 09.02.2015 23:15, Martin Landa wrote:
Hi Ivan,
I solved that by
-> gbp:error: You have uncommitted changes in your source tree:
gbp:error: On branch master Untracked files: (use "git add
debian/.bzr/ debian/README.Debian debian/README.RunningWithoutGUI
debian/README.source ... nothing added to commit but untracked
OK, I tried
--git-builder="debuild -S -sa" --git-ignore-new
but it failed with
dpkg-buildpackage -rfakeroot -d -us -uc -S -sa dpkg-buildpackage:
source package grass70 dpkg-buildpackage: source version
7.0-1~svn55286~ubuntu2 dpkg-buildpackage: source distribution
quantal dpkg-buildpackage: source changed by Rashad M
<mohammedrashadkm@gmail.com> dpkg-source --before-build pkg-grass
directory make: *** No rule to make target
'/usr/share/dpatch/dpatch.make'. Stop. dpkg-buildpackage: error:
fakeroot debian/rules clean gave error exit status 2 debuild: fatal
error at line 1376: dpkg-buildpackage -rfakeroot -d -us -uc -S -sa
failed gbp:error: 'debuild -S -sa' failed: it exited with 29
Thanks a lot! Martin>
Sorry for late response, I have missed your emails somehow.
Try to install 'dpatch' package on your system.
Ivan Min?ík
Version: GnuPG v1
iQEcBAEBAgAGBQJU2V5pAAoJEPfdLsR5Upoe/pwH/294vq0EKzKFAIKaMXyuoguy
WB8y5MP0ZHFcVLiyLHCltqP2SRxkFgPYUrIxQwNRc4TvLuMzXLmJHABiaS4JmPy2
jIRnvruaEA2csEKx6BCcOIA9VwKbXNxi1b9PYuqi5SvtEHk6gdmD0dUn+H8wiXm2
Ldb7IEd7NXJe++j0CacVI6S2KR1IPMEK1U0i+AMTsXbmWanS6LptEzvBiesTAS5k
FSE6FBB7tQWEqCP8q8c83vuHTW7wPkPtnMFFCRu9cjIk1mMojwQ9qBY5PQxscA6Q
nlrIJQ5uqAYPhTwyQs8ACHxMnMCgMnang1BfrcDV9fQnEF2spTp0lP1kM0yTLU4=
=Vm8o
2015-02-10 2:27 GMT+01:00 Ivan Mincik <ivan.mincik@gmail.com>:
ops, you are right. Unfortunately the command now fails with:
dpkg-source -b pkg-grass
dpkg-source: error: can't build with source format '3.0 (native)':
native package version may not have a revision
dpkg-buildpackage: error: dpkg-source -b pkg-grass gave error exit status 255
Martin
Martin Landa
Hash: SHA1
On 10.02.2015 09:34, Martin Landa wrote:
Sorry for late response, I have missed your emails somehow. Try
--git-builder="debuild -S -sa" --git-ignore-new ... dpkg-source -b
pkg-grass dpkg-source: info: using options from
native package version may not have a revision dpkg-buildpackage:
error: dpkg-source -b pkg-grass gave error exit status 255 debuild:
fatal error at line 1376: dpkg-buildpackage -rfakeroot -d -us -uc
-S -sa failed gbp:error: 'debuild -S -sa' failed: it exited with
29
The core of the problem lies in invalid Debian packaging format
configuration, which is set to native in 'debian/source/format' which
can not contain Debian revision number in version (value you entered
in debian/changelog file). 'native' packages are only packages, which
are developed directly in Debian project, thus upstream is Debian and
no revision is needed. GRASS is not native one.
We should really move to Debian packaging done inside of DebianGIS [1]
for final 7.0 version (Sebastiaan from DebianGIS in CC). I can provide
some help for this.
As a quick solution for your problem, is to set package version in
debian/chagelog to something like 7.0.0~RC2-1 [2]
1 - http://anonscm.debian.org/cgit/pkg-grass/grass.git/log/?h=experimental
2 -
https://www.debian.org/doc/debian-policy/ch-controlfields.html#s-f-Version
Ivan Minčík
Version: GnuPG v1
iQEcBAEBAgAGBQJU2jbxAAoJEPfdLsR5Upoe9RAH/0ZAaqhy4Acm5GGkwr+D4kFX
ighxrB+DdnUq4W1SCWPRSnCzm6sXqJM/qswHNBvU6l7EqlZKfBFZy6ALKCCuogvX
E+Z6UkUZ8xbPlmD3bgAVQcdYthldYmVjrOjQdlKF1Bzl+WVzKEXNRGMNaj286hpk
8UuP70OsE/Ph+5MUP4nhb7c4We+/LnVKP8XtLkiHEeHA0binSMFM7TkoXyRgcAgD
H9uHxaXPDbeCOpnDSIYZyAtuQC7e4eTkCQLTEf0tpLN7hbVeabWr/PqBli3hJ7yk
DxShrM4Oo+GPihaK3QoUE8F9eEtpyVbNx+cEq1BGM6lIvKIJG5Iafl9kesk6iog=
=QNOA
Hi Ivan,
2015-02-10 9:34 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
I managed to solve this problem, the last command I entered was:
dput ppa:grass/grass-stable ../grass70_7.0.0RC2-1_source.changes
it seems to be OK
Uploading to ppa (via ftp to ppa.launchpad.net):
  Uploading grass70_7.0.0RC2-1.dsc: done.
  Uploading grass70_7.0.0RC2-1.tar.gz: done.
  Uploading grass70_7.0.0RC2-1_source.changes: done.
But I cannot find at Launchpad [1] any "button" where I could launch
building process...
Thanks again for the patience (being debian user who has no experience
with creating packages)! Martin
[1] https://launchpad.net/~grass/+archive/ubuntu/grass-stable/+packages
Martin Landa
2015-02-10 17:51 GMT+01:00 Ivan Mincik <ivan.mincik@gmail.com>:
some help for this.
seems to be reasonable to me.
done, btw, why '~'? Is it some kind of naming convention? I would
expect just 7.0.0RC2-1.
Martin
Martin Landa
On Wed, Feb 11, 2015 at 3:54 PM, Martin Landa <landa.martin@gmail.com>
Semantic Versioning 2.0.0 says you should use hyphen (7.0.0-RC2-1).
Semantic Versioning 1.0.0-beta used nothing (7.0.0RC2-1).
http://semver.org/
Hash: SHA1
On 11.02.2015 21:52, Martin Landa wrote:
Hi Ivan,
dpkg-source -b pkg-grass dpkg-source: info: using options from
debuild: fatal error at line 1376: dpkg-buildpackage -rfakeroot
-d -us -uc -S -sa failed gbp:error: 'debuild -S -sa' failed: it
exited with 29
it seems to be OK
Uploading to ppa (via ftp to ppa.launchpad.net): Uploading
grass70_7.0.0RC2-1.dsc: done. Uploading grass70_7.0.0RC2-1.tar.gz:
done. Uploading grass70_7.0.0RC2-1_source.changes: done.
launch building process...
I will start to build automatically once source package is uploaded
:). No other manual action is needed.
experience with creating packages)! Martin
[1]
Ivan Min?ík
Version: GnuPG v1
iQEcBAEBAgAGBQJU2+WjAAoJEPfdLsR5UpoetgwH/2KnE5dzLceZ5by3JOQD3dA/
gBFUhUBpofEUG3M+1KsBHU+Jox4gxKVl+x+cIzU7ZTpMgB+PT1oGhJJHrNWFLt2C
KpjcgUIMMbsgW5j6ris9JYyoL8f+CKMU7/gYQjKSUxXpKfXcq1ty1VxJY19/G2m5
iOWBFlwaYb5pc4erU45VOIpBiv/KcfyHcQ2qdPG0S4p55dEaGmpgKlASWVTDOS28
RBlZE+5A1Rxatb49ExUuH11UejIj4iJqniEtTH3UtnJjNIirEaaxQQ13w+Dq4qjE
shXrgCJpWcWqg+J/ACIZPWcKCAQ1Rc0H2XuWGGTSG8vHotvxBAtI45oyCi69g2c=
=aIZ7
2015-02-12 0:28 GMT+01:00 Ivan Mincik <ivan.mincik@gmail.com>:
thats a problem, nothing else happen till now [1]. I will try it once
more. Martin
Martin Landa
2015-02-12 7:53 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
more. Martin
hm,
Package has already been uploaded to ppa on ppa.launchpad.net
Nothing more to do for ../grass70_7.0.0RC2-1_source.changes
Any idea where to find out what is wrong? Thanks in advance! Martin
Martin Landa
2015-02-12 7:54 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
there are no builds yet, something must be wrong. Not sure what to check... [1].
Martin
[1] http://askubuntu.com/questions/26129/upload-to-ppa-succeeded-but-packages-doesnt-appear
Martin Landa
more. Martin
hm,
when I was creating a package I was forced to sign it. On Launchpad I
discovered that I have no OpenPGP keys registered. Could be that a
reason? I guess no since it was uploaded to Lauchpad successfully.
Just guessing...
Martin
Martin Landa
Hash: SHA1
it once more. Martin
[1]
hm,
Martin
I discovered that I have no OpenPGP keys registered. Could be that
a reason? I guess no since it was uploaded to Lauchpad
successfully. Just guessing...
Martin,
GPG key should be required. Also, I receive email from Launchpad every
time my source package is accepted (check spam if you do not have some
refusal message from Launchpad). I was checking 'grass-stable' and no
new package is waiting for build. Most probably it was refused.
Ivan Minčík
Version: GnuPG v1
iQEcBAEBAgAGBQJU3RJZAAoJEPfdLsR5UpoeHNIH/AzJ0RD24GkVwOfoCAWXdhxw
QlZCXniPsirFs76IZI+l7Ou2zDD6PrG9Fu4jzKOYdelHU+pNTuv/kgwEpaLqaM9o
dvL8I8CYvgrU+JaS4m/u4SxKxubWYJh8mIajMewE7/7PcPHrhRianbxb8bZat07B
8BJ/eOTlJywvzNNVo3ECovrWONkcbiOoVKnGURFl5imUi4s2BjPaRqxTSlGDSovO
h+0jzHWg/o1s89qGsJVpwZsc+kOWq0dCDwNeFHH3K2pcP+dl5QLRAEngYbbTUd0S
PSVUs616l70bUQtF3qVaY9qZxjk04X3shwiVCrREj9N/6kcv0v0QubzhSOKcpfI=
=qCrb
2015-02-12 21:51 GMT+01:00 Ivan Mincik <ivan.mincik@gmail.com>:
it's working also for me when I push button "Request build" on
Launchpad, but not this time.
I contacted Launchpad Support [1]. Thanks, Martin
[1] https://answers.launchpad.net/launchpad/+question/262058
Martin Landa
some help for this.
let's try it. I can help with that, I am just new in debian packaging
process (even I am Debian user since 2005). So please have patience
with me :slight_smile:
Martin
Will take a look.
Martin Landa
2015-02-13 15:13 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
Will take a look.
I switched to upstream branch where is 7.0.0RC2, but I didn't find
`debian` directory (?)
Martin
Martin Landa
