[GRASS-dev] CI test timeout
Hei,
After adding another case to the t.rast.algebra test, the tesuite occasionally fails due to test time-out. See:
https://github.com/OSGeo/grass/actions/runs/4394593270/jobs/7699431483#step:11:236
The t.rast.algebra test has quite a number of test cases…
My question is, what is the appropriate solution here:
  1. split up the test, so that tests savely finish within 300 seconds threshold? The drawback is that the creation of testdata in those tests often takes ~ 20 to 50 seconds, which is an overhead in each testfile o
  2. increase the time-out limit a bit, so the test does not fail…
Stefan
Hi Stefan,
On Sun, 12 Mar 2023 at 08:45, Stefan Blumentrath <Stefan.Blumentrath@gmx.de> wrote:
Any temporal test can fail with timeout. Not only this one. I think this one is most commonly failing because it has the most tests, not because it is more wrong then the others.
I think the split would just increase the time for good cases and while the number of processes which may hang will remain the same.
I think I have some comments about it here:
https://github.com/OSGeo/grass/issues/2185
  1. increase the time-out limit a bit, so the test does not fail…
I think the tests hang, not simply take a little longer. Before the time limit, they would take (the full) 6 hours. So, increasing the test time limit would make it fail later, but that’s all.
The actual problem is unknown, but I don’t know if anyone tried like 100-500 tests in a row locally to see what happens. The test results are available for download even when the tests fail (to help track down this problem).
Vaclav
Stefan
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
