[GRASS-dev] [cmbarton.wikidot.com] Contact via Wikidot.com
This is a weird error. I built these binaries against OS X 10.7 and am sure that they work with Mavericks (10.9). But I only have Mavericks. So I'm copying some of the GRASS developers in the hopes that someone else can test.
Michael
On May 19, 2014, at 1:13 AM, Wikidot.com <sender@wikidot.com> wrote:
Form data:
First name, last name:
John Payne
Organization/Company:
Wildlife Conservation Society
Country:
Mongolia
Email:
jcpayne@uw.edu
Your message (5000 character max):
Hi Michael, I just tried installing both of the binaries for Grass 7 (7.0.beta2 and 7.1) on a new Mac (OS X 10.8.5), and got a message both times saying something like "Wrong operating system" (I since successfully installed 6.4, but I really need some of the new features of 7). It wasn't clear to me from your release notes whether the binaries only worked for Mavericks. Thanks, John
You have another Python installed in /opt in addition to the system Python. The computer is confused. You will need to change your path or python path to allow GRASS to use your system Python only. Also, the Mac binaries bundle wxPython with the program. You don't need to install this. If you have it, you should probably have exactly the same version that was used for compiling. Currently, I'm using 2.8.12.
Michael Barton
On May 21, 2014, at 4:27 PM, John Payne <jpayne@wcs.org> wrote:
Hi Michael,
Thank you very much for your help -- I just reinstalled it so that I could
send you the error message (the installation always completes
successfully) and here is the precise error message that I get when I try
to run it (I get the same message with 7.0.beta2):
Johns-MacBook-Pro:~ john$
'/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
dyld: DYLD_ environment variables being ignored because main executable
(/usr/bin/osascript) is code signed with entitlements
Python 2.7.5 found.
arch: posix_spawnp: /opt/local/bin/pythonw2.7: Bad CPU type in executable
logout
John
can test.
Michael
Form data:
John Payne
Country:
Mongolia
Email:
jcpayne@uw.edu
I haven't installed PostGIS, so you'll have to ask William about that. But I do have Mavericks, GRASS 6 and 7, and QGIS v. 2 working together. I don't know how to best set the environment to use the system python. It is best to ask the list if someone has done this (copied here). OS X is a version of Unix, which is similar but not identical to Linux. Many of the configuration files for setting environmental variables are similar between OS X and Linux, but they can vary sometimes.
Michael Barton
On May 22, 2014, at 5:32 AM, John Payne <jpayne@wcs.org> wrote:
Hi Michael,
Thank you -- I remember reading about conflicts between multiple Python
versions but I don't know how to tell whether the /opt version is being
used by other software so I'm hesitant to remove it. I haven't switched
to Mavericks yet for fear that it would break things, but perhaps it's
time to take the plunge. It looks to me as though you and William
Kyngesbury have made it possible to install this combination:
Mavericks
PostgreSQL with PostGIS (postGIS is critical to me)
GRASS 7
QGIS
Šbut please tell me if that is not the case.
Also can you tell me which environment variable I need to change to "allow
GRASS to use the system Python only"? I hate to waste your time, but
being an ex-Windows user, these OS X installations seem like black magic
to me and the OS X books that I've seen are all way too general to be
useful ("push the big happy button and you're done!"). Maybe Unix books
are more useful? I'm guessing that experts like you simply learn the hard
way, by experience, but I would love to be able to study on my own if you
have any recommendations.
Lastly, I have been using MacPorts and I see that they have wxPython
version 2.8.12.1. Is that close enough to the one that you compiled with?
John
Michael Barton
Hi Michael,
could
try
Python 2.7.5 found.
executable
logout
John
So
can test.
Michael
Form data:
John Payne
Country:
Mongolia
Email:
jcpayne@uw.edu
The way the GRASS-Mac startup is configured, it looks for python in this order:
  what's set in GRASS_PYTHON (full path to pythonw, needed for wxpython GUI)
  what is found in the PATH (/opt is probably in your PATH)
  the python.org Python (/Library/Frameworks)
  the system python
It checks each for the python version needed, but not the architecture. the error you are getting is probably because GRASS needs to run python 32bit because of Wxpython limitations, but the /opt python is 64bit only. That's odd that macports does that since you need wxpython 3 to be able to run 64bit. But GRASS should have its own wxpython bundled, and it's best to use the python it was compiled for (system python as Michael said).
On May 22, 2014, at 4:31 AM, Michael Barton <c.michael.barton@gmail.com> wrote:
Michael Barton
Hi Michael,
Mavericks
GRASS 7
QGIS
John
Michael Barton
Hi Michael,
could
try
Python 2.7.5 found.
executable
logout
John
So
can test.
Michael
Form data:
John Payne
Country:
Mongolia
Email:
jcpayne@uw.edu
grass-dev mailing list
grass-dev@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
Sounds like the Macports python is loading the system python global site-packages (/Library/Python). Bad form really, because you can't expect modules to work between different builds of python, even if they're the same version. Maybe there is some option in Macports python to exclude the system site-packages.
To get GRASS to always use the system python, just set GRASS_PYTHON (you can set this in your .bash_profile):
export GRASS_PYTHON=/usr/bin/pythonw2.7
The version is important because of the way GRASS forces 32bit.
On May 22, 2014, at 10:28 AM, Adam Dershowitz <adershowitz@exponent.com> wrote:
In my case, the problem was that I had uninstalled NumPy (from kyngchaos
GDAL). It was causing a conflict with Macports scipy stuff. The macports
version is installed as "universal" but apparently is actually just 64
bit!
So the workaround I have at the moment is to install NumPy when I need to
use GRASS 7, and then uninstall so I can use macports python (which I need
for other libraries and such).
This seems like a inconvenient fix for now. Is there any way to set some
paths so that they can both co-exist and GRASS will find the correct one?
-- Adam
On 5/22/14, 10:12 AM, "Adam Dershowitz" <adershowitz@exponent.com> wrote:
Just to add a bit more data. I have a 10.9 machine and also use macports,
so have macports python 2.7 installed.
The Kyngchaos 6.4 seems to run just fine. But, I recently tried Grass
7.0.beta2 (Barton) and I have also run into python errors.
If I just try to run it I get this error:
ImportError:
dlopen(/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/pyt
h
on2.7/site-packages/numpy/core/multiarray.so, 2): no suitable image found.
Did find:
  /opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7
site-packages/numpy/core/multiarray.so: mach-o, but wrong architecture
So, I tried switching to System python:
sudo port select python python27-apple
But, oddly, got the same error. So, it seems to still be using Macports
numpy. But, then I tried setting:
setenv GRASS_PYTHON /usr/bin/pythonw
And now I get a different error:
GRASS 7.0.0svn (KDEN):~ > g.gui
Launching <wxpython> GUI in the background, please wait...
File
"/Applications/Grass/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py",
line 25, in <module>
  from core import globalvar
File
"/Applications/Grass/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/global
v
ar.py", line 84, in <module>
  import wx
File
"/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/python/wx/__init__.p
y
", line 45, in <module>
  from wx._core import *
File
"/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py",
line 4, in <module>
  import _core_
ImportError:
/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core_.so:
no appropriate 64-bit architecture (see "man python" for running in 32-bit
mode)
But, now it is trying to use the library included with Grass, but still
isn't working.
-- Adam
order:
GUI)
the system python
said).
Michael Barton
Hi Michael,
Python
being
switched
Mavericks
GRASS 7
QGIS
"allow
magic
books
hard
you
with?
John
or
Mac
version
Michael Barton
Hi Michael,
could
I
try
executable
Python 2.7.5 found.
executable
logout
John
am
Mavericks.
So
else
can test.
Michael
wrote:
Form data:
John Payne
Country:
Mongolia
Email:
jcpayne@uw.edu
7
both
features
grass-user mailing list
grass-user@lists.osgeo.org
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
Please add the outcome (solution) to this Wiki page:
http://grasswiki.osgeo.org/wiki/MacOSX_GRASS_errors
thanks
On Fri, May 23, 2014 at 10:22 AM, John Payne <jcpayne@uw.edu> wrote:
I set the path in .bash_profile set as you suggested ("export
GRASS_PYTHON=/usr/bin/pythonw2.7"), and that did the trick--Grass 7 is now
running on my Mac with OS X 10.8.5. Thank you all VERY much for your help.
For the future, I would love to know whether it is possible to install the
following combination in Mavericks, using the KyngChaos builds:
--PostgreSQL with PostGIS (postGIS is critical to me)
--GRASS 7
--QGIS
Thanks again,
John
On Fri, May 23, 2014 at 2:32 AM, William Kyngesburye <woklist@kyngchaos.com>
> macports
> bit!
> to
> need
> some
> one?
> -- Adam
>> macports,
>> ImportError:
>> h
>> found.
>> Did find:
>> Macports
>> File
>> File
>> v
>> import wx
>> File
>> y
>> File
>> line 4, in <module>
>> import _core_
>> ImportError:
>> 32-bit
>> mode)
>> isn't working.
>> -- Adam
>>> this
>>> order:
>>> GUI)
>>> the system python
>>> architecture.
>>> python
>>> only.
>>> able
>>> it's
>>> said).
>>>> that.
>>>> together.
>>>> python.
>>>> X
>>>> Many
>>>> Michael Barton
>>>>> Hi Michael,
>>>>> Python
>>>>> being
>>>>> switched
>>>>> it's
>>>>> Mavericks
>>>>> GRASS 7
>>>>> QGIS
>>>>> "allow
>>>>> but
>>>>> magic
>>>>> be
>>>>> books
>>>>> the
>>>>> hard
>>>>> if
>>>>> you
>>>>> with?
>>>>> Thanks,
>>>>> John
>>>>>> or
>>>>>> the
>>>>>> Mac
>>>>>> install
>>>>>> version
>>>>>> Michael Barton
>>>>>>> Hi Michael,
>>>>>>> I
>>>>>>> could
>>>>>>> when
>>>>>>> I
>>>>>>> try
>>>>>>> executable
>>>>>>> Python 2.7.5 found.
>>>>>>> executable
>>>>>>> logout
>>>>>>> John
>>>>>>>> and
>>>>>>>> am
>>>>>>>> Mavericks.
>>>>>>>> So
>>>>>>>> someone
>>>>>>>> else
>>>>>>>> can test.
>>>>>>>> Michael
>>>>>>>> wrote:
>>>>>>>>> Form data:
>>>>>>>>> John Payne
>>>>>>>>> Country:
>>>>>>>>> Mongolia
>>>>>>>>> Email:
>>>>>>>>> jcpayne@uw.edu
>>>>>>>>> Grass
>>>>>>>>> 7
>>>>>>>>> message
>>>>>>>>> both
>>>>>>>>> features
>>>>>>>>> the
>>>> _______________________________________________
>>> what
>>> and
- Marvin
I can definitely say yes to all except PG. If I have a chance, I’ll try to install William’s PGIS over the next few weeks and let you know.
Michael Barton
On Fri, May 23, 2014 at 2:32 AM, William Kyngesburye <woklist@kyngchaos.com> wrote:
Sounds like the Macports python is loading the system python global site-packages (/Library/Python). Bad form really, because you can’t expect modules to work between different builds of python, even if they’re the same version. Maybe there is some option in Macports python to exclude the system site-packages.
version is installed as “universal” but apparently is actually just 64
bit!
– Adam
ImportError:
h
Did find:
Launching GUI in the background, please wait…
File
“/Applications/Grass/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py”,
line 25, in
File
“/Applications/Grass/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/global
v
ar.py”, line 84, in
import wx
File
"/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/python/wx/init.p
y
", line 45, in
File
“/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py”,
line 4, in
import core
ImportError:
/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/python/wx/core.so:
no appropriate 64-bit architecture (see “man python” for running in 32-bit
mode)
isn’t working.
– Adam
order:
what’s set in GRASS_PYTHON (full path to pythonw, needed for wxpython
GUI)
the system python
That’s odd that macports does that since you need wxpython 3 to be able
to run 64bit. But GRASS should have its own wxpython bundled, and it’s
said).
wrote:
I haven’t installed PostGIS, so you’ll have to ask William about that.
I don’t know how to best set the environment to use the system python.
Michael Barton
Hi Michael,
Thank you – I remember reading about conflicts between multiple
Python
versions but I don’t know how to tell whether the /opt version is
being
used by other software so I’m hesitant to remove it. I haven’t
switched
to Mavericks yet for fear that it would break things, but perhaps it’s
Mavericks
GRASS 7
QGIS
“allow
GRASS to use the system Python only”? I hate to waste your time, but
magic
to me and the OS X books that I’ve seen are all way too general to be
useful (“push the big happy button and you’re done!”). Maybe Unix
books
are more useful? I’m guessing that experts like you simply learn the
hard
you
with?
John
On 5/21/14 11:15 PM, “Michael Barton” <c.michael.barton@gmail.com>
or
Mac
binaries bundle wxPython with the program. You don’t need to install
version
that was used for compiling. Currently, I’m using 2.8.12.
Michael Barton
Hi Michael,
Thank you very much for your help – I just reinstalled it so that I
could
I
try
‘/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/grass.sh’; exit
Rebuilding Addon HTML manual pages index…
Rebuilding Addon menu…
executable
Python 2.7.5 found.
executable
logout
John
On 5/20/14 1:11 AM, “Michael Barton” <c.michael.barton@gmail.com>
am
Mavericks.
So
I’m copying some of the GRASS developers in the hopes that someone
else
can test.
Michael
wrote:
Form data:
John Payne
Country:
Mongolia
Email:
jcpayne@uw.edu
7
both
times saying something like “Wrong operating system” (I since
features
of 7). It wasn’t clear to me from your release notes whether the
William Kyngesburye <kyngchaosatkyngchaosdotcom>
-Hitchhiker’s Guide to the Galaxy 2nd season intro
“Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life.”
  • Marvin
GRASS needs to be compiled with Postgres support to be able to store attribute data in Postgres. Last I checked it doesn't handle Postgis directly, it's an import and uses GDAL, so it doesn't need Postgres support for that.
On May 23, 2014, at 4:17 AM, Michael Barton <c.michael.barton@gmail.com> wrote:
I can definitely say yes to all except PG. If I have a chance, I'll try to install William's PGIS over the next few weeks and let you know.
Michael Barton
On May 23, 2014, at 10:22 AM, John Payne <jcpayne@uw.edu> wrote:
I set the path in .bash_profile set as you suggested ("export GRASS_PYTHON=/usr/bin/pythonw2.7"), and that did the trick--Grass 7 is now running on my Mac with OS X 10.8.5. Thank you all VERY much for your help.
For the future, I would love to know whether it is possible to install the following combination in Mavericks, using the KyngChaos builds:
--GRASS 7
--QGIS
Thanks again,
John
> bit!
> -- Adam
>> ImportError:
>> h
>> Did find:
>> File
>> File
>> v
>> import wx
>> File
>> y
>> File
>> line 4, in <module>
>> import _core_
>> ImportError:
>> mode)
>> isn't working.
>> -- Adam
>>> order:
>>> GUI)
>>> the system python
>>> said).
>>>> Michael Barton
>>>>> Hi Michael,
>>>>> Python
>>>>> being
>>>>> switched
>>>>> Mavericks
>>>>> GRASS 7
>>>>> QGIS
>>>>> "allow
>>>>> magic
>>>>> books
>>>>> hard
>>>>> you
>>>>> with?
>>>>> Thanks,
>>>>> John
>>>>>> or
>>>>>> Mac
>>>>>> version
>>>>>> Michael Barton
>>>>>>> Hi Michael,
>>>>>>> could
>>>>>>> I
>>>>>>> try
>>>>>>> executable
>>>>>>> Python 2.7.5 found.
>>>>>>> executable
>>>>>>> logout
>>>>>>> John
>>>>>>>> am
>>>>>>>> Mavericks.
>>>>>>>> So
>>>>>>>> else
>>>>>>>> can test.
>>>>>>>> Michael
>>>>>>>> wrote:
>>>>>>>>> Form data:
>>>>>>>>> John Payne
>>>>>>>>> Country:
>>>>>>>>> Mongolia
>>>>>>>>> Email:
>>>>>>>>> jcpayne@uw.edu
>>>>>>>>> 7
>>>>>>>>> both
>>>>>>>>> features
- Marvin
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
Just FYI
On Fri, May 23, 2014 at 5:35 PM, William Kyngesburye
GRASS GIS 7 can do that ... (under development):
http://trac.osgeo.org/grass/wiki/Grass7/VectorLib/PostGISInterface
ImportError:
dlopen(/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/pyth
Did find:
  /opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/
  File
  File
"/Applications/Grass/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/globalv
    import wx
  File
"/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/python/wx/__init__.py
  File
line 4, in <module>
    import _core_
ImportError:
mode)
isn't working.
-- Adam
order:
GUI)
the system python
said).
Michael Barton
Hi Michael,
switched
Mavericks
GRASS 7
QGIS
"allow
magic
books
hard
you
with?
John
Mac
version
Michael Barton
Hi Michael,
could
try
executable
Python 2.7.5 found.
executable
logout
John
am
Mavericks.
So
else
can test.
Michael
Form data:
John Payne
Country:
Mongolia
Email:
jcpayne@uw.edu
7
both
features
bit!
-- Adam
ImportError:
h
Did find:
File
File
v
   import wx
File
y
File
line 4, in <module>
   import _core_
ImportError:
mode)
isn't working.
-- Adam
order:
GUI)
the system python
said).
Michael Barton
Hi Michael,
Python
being
switched
Mavericks
GRASS 7
QGIS
"allow
magic
books
hard
you
with?
John
or
Mac
version
Michael Barton
Hi Michael,
could
I
try
executable
Python 2.7.5 found.
executable
logout
John
am
Mavericks.
So
else
can test.
Michael
wrote:
Form data:
John Payne
Country:
Mongolia
Email:
jcpayne@uw.edu
7
both
features
Now, I can't seem to reproduce the error I was having. So maybe macports
has fixed this, and is now loading only its own stuff. At least I will
assume that for now, until I run into the bug again.
-- Adam
macports
bit!
to
need
some
one?
-- Adam
macports,
ImportError:
yt
h
found.
Did find:
.7
Macports
File
File
al
v
  import wx
File
.p
y
File
line 4, in <module>
  import _core_
ImportError:
32-bit
mode)
isn't working.
-- Adam
this
order:
GUI)
the system python
architecture.
python
only.
able
it's
said).
that.
together.
python.
OS X
Many
Michael Barton
Hi Michael,
Python
being
switched
it's
Mavericks
GRASS 7
QGIS
"allow
but
magic
be
books
the
hard
if
you
with?
John
or
the
Mac
install
version
Michael Barton
Hi Michael,
that I
could
when
I
try
executable
Python 2.7.5 found.
executable
logout
John
and
am
Mavericks.
So
someone
else
can test.
Michael
wrote:
Form data:
John Payne
Country:
Mongolia
Email:
jcpayne@uw.edu
Grass
7
message
both
features
the
what
and
- Marvin
I set the path in .bash_profile set as you suggested (“export GRASS_PYTHON=/usr/bin/pythonw2.7”), and that did the trick–Grass 7 is now running on my Mac with OS X 10.8.5. Thank you all VERY much for your help.
–PostgreSQL with PostGIS (postGIS is critical to me)
–GRASS 7
–QGIS
Thanks again,
John
bit!
– Adam
ImportError:
h
Did find:
File
line 25, in
File
v
ar.py”, line 84, in
import wx
File
y
", line 45, in
File
line 4, in
import core
ImportError:
mode)
isn’t working.
– Adam
order:
GUI)
the system python
said).
Michael Barton
Hi Michael,
Python
being
switched
Mavericks
GRASS 7
QGIS
“allow
magic
books
hard
you
with?
John
or
Mac
version
Michael Barton
Hi Michael,
could
I
try
executable
Python 2.7.5 found.
executable
logout
John
am
Mavericks.
So
else
can test.
Michael
wrote:
Form data:
John Payne
Country:
Mongolia
Email:
jcpayne@uw.edu
7
both
features
  • Marvin
