[GRASS-dev] compilation error
Hello,
I tried to compile GRASS trunk.
Why do I get this error:
ERROR: Incompatible library version for module. You need to rebuild GRASS
        or untangle multiple installations.
make[2]: *** [db.tables.tmp.html] Fehler 1
Thanks in advance,
Timmie
After Hamish recommended
make distclean
I got a litle further.
Now the next break:
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:23:29: Fehler: ogr_srs_api.h: No such file or directory
In file included from proj_wrap.c:2694:
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:84: Fehler: expected »=«, »,«, »;«, »asm« or »__attribute__« before »GPJ_grass_to_osr«
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:88: Fehler: expected declaration specifiers or »...« before »OGRSpatialReferenceH«
make[3]: *** [OBJ.i686-pc-linux-gnu/proj_wrap.o] Fehler 1
What does this mean?
Kind regards,
Timmie
Hello,
thanks to Hamish for the assistance.
As the trunk failed I tried grass64:
svn co of https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4
CFLAGS="-g -Wall" ./configure --with-cxx --with-freetype=yes --with-postgres=no --with-sqlite=yes --enable-largefile=yes --with-tcltk-includes=/usr/include/tcl8.4 --with-freetype-includes=/usr/include/freetype2 --with-opengl-libs=/usr/include/GL --with-readline --with-python=yes --program-suffix=SVN
=> no suffix appended:
ls ./bin.i686-pc-linux-gnu/
insgesamt 4,0K
-rwxr-xr-x 1 timmie users 1005 2009-06-12 14:26 grass64
then when entering a mapset, a wxpython window opens telling: "g.proj -p fails"
I have proj installed.
What can I do?
insgesamt 4,0K
Any idea why there is no suffix appended?
I want to have
grass64SVN
Timmie
