[GRASS-dev] compile error in grass-6.4.0RC1/gui/wxpython
Dear developers,
I wanted to build GRASS 6.4.0 RC1 packages under OpenSuSE 11.0 and got errors in
grass-6.4.0RC1/gui/wxpython. I changed into the directory and tried with 'make'
again. I attached the error messages, maybe someone can have a look and help?
thanks a lot
Otto
(attachments)
wxpython_error.txt (27.3 KB)
Dear developers,
On Mon, 29 Dec 2008 16:07:30 +0100
Otto Dassau <otto.dassau@gmx.de> wrote:
Dear developers,
in grass-6.4.0RC1/gui/wxpython. I changed into the directory and tried with
'make' again. I attached the error messages, maybe someone can have a look and
help?
after reading and following the README in
http://svn.osgeo.org/grass/grass/branches/develbranch_6/gui/wxpython/ I still
get some error messages:
make[3]: Entering directory
`/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython' python
gui_modules/menudata.py
/usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu > menustrings.py
Traceback (most recent call last): File "gui_modules/menudata.py", line 24, in
<module> import elementtree.ElementTree as etree # Python <= 2.4
ImportError: No module named elementtree.ElementTree
make[3]: *** [menustrings.py] Error 1
make[3]: Leaving directory `/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython'
make[2]: *** [install_scripts] Error 2
make[2]: Leaving directory `/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython'
make[1]: Leaving directory `/usr/src/packages/BUILD/grass-6.4.0RC1/gui'
make[1]: Entering directory `/usr/src/packages/BUILD/grass-6.4.0RC1/imagery'
Maybe someone has an idea what to do here? Is there something else (a python
module) missing?
thanks a lot
  Otto
thanks a lot
Otto
2009/1/7 Otto Dassau <otto.dassau@gmx.de>:
in Debian it's python-elementtree.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
What? As in, they renamed the module so it doesn't work?
elementtree.ElementTree (xml.etree.ElementTree in >= 2.5) is part of
the core Python library, which is expected to be installed alongside
Python.
thanks Martin, the python-elementtree package was missing as you suggested. Now
there is the wxpython vdigit problem described in gui/wxpython/README. Hopefully
the final hurdle to clear. I get a
/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/vdigit# make
/usr/lib/gcc/i586-suse-linux/4.3/../../../../i586-suse-linux/bin/ld: cannot find
-lgdi
is there a chance to have another solution for this wxpython vdigit problem,
than to create a symlink to _gdi_.so shared library? This seems to be quite
difficult to solve / implement in a spec file.
Maybe someone already has a solution for that?
kind regards,
Otto
On Wed, 7 Jan 2009 15:55:14 +0100
Dear developers,
> Dear developers,
> errors
> and help?
module) missing?
thanks a lot
  Otto
> thanks a lot
> Otto
grass-dev mailing list
grass-dev@lists.osgeo.org
2009/1/7 Glynn Clements <glynn@gclements.plus.com>:
Python.
hm, it seems to me that if you are using python <= 2.4 you need to
install python-elementtree package - at least on Debian.
Martin
On Thu, 8 Jan 2009 15:20:55 +0100
"Martin Landa" <landa.martin@gmail.com> wrote:
>> > menustrings.py
>> > 24, in
> Python.
the problem above occurs with opensuse 11.0 (python 2.5.2). Maybe this
information is helpful:
http://lists.opensuse.org/opensuse-factory/2007-02/msg00177.html
Otto
Martin
2009/1/8 Otto Dassau <otto.dassau@gmx.de>:
-lgdi
currently no, see
http://trac.osgeo.org/grass/ticket/58
I still hope reasonable solution will be found before 6.4.0.
Martin
I have now changed the OpenSuSE build server from GRASS 6.3 to 6.4 RC1. As for
the version 6.3 I commented gui/wxpython/vdigit in gui/wxpython/Makefile to make
it build.
Packages are available for OpenSuSE 10.3, SLE_10, 11.0 and 11.1 i586 and x86_64.
Can you please add this change to http://grass.osgeo.org/download/index.php and
move the OpenSUSE Geo Repository link from 6.3 to 6.4?
thanks a lot
Otto
On Thu, 8 Jan 2009 15:36:22 +0100
> Hi,
> >> > menustrings.py
> >> > 24, in
> > Python.
Otto
> Martin
On Fri, Jan 9, 2009 at 4:04 PM, Otto Dassau <otto.dassau@gmx.de> wrote:
it build.
(I assume due to the libgdi.so issue?)
Shouldn't --without.wxpython work?
Done:
http://grass.osgeo.org/download/index.php#g64x
thanks a lot
Otto
> Hi,
> >> > menustrings.py
> >> > 24, in
> > Python.
Otto
> Martin
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
On Fri, 9 Jan 2009 16:44:53 +0100
> Hi,
> for
> make it build.
yes
would that mean wxpython gui won't be build at all? Is that a configure option?
At the moment everything should work, except wxpython gui vdigit.
> x86_64.
> and move the OpenSUSE Geo Repository link from 6.3 to 6.4?
Done:
thanks!
Otto
> thanks a lot
> Otto
>> > Hi,
>> > >> > menustrings.py
line
>> > >> > 24, in
>> > > Python.
>> Otto
>> > Martin
>> _______________________________________________
2009/1/9 Markus Neteler <neteler@osgeo.org>:
it build.
if you configure '--with-widgets=no' wxVdigit and xwNviz will be not compiled.
Martin
2009/1/9 Otto Dassau <otto.dassau@gmx.de>:
wxGUI is available regardless --with-python/c++/wxwidgets. These
options are needed just for vdigit and nviz extension compilation.
Martin
> -lgdi
currently no, see
The solution is to take the wxPseudoDC code, change the name to avoid
conflicts, then add it to gui/wxpython/vdigit.
If the wxPython developers wanted you to use _gdi_.so as a normal
library, they would have named it libgdi.so.
> > for
> > make it build.
yes
The relevant configure options are --with-python and --with-wxwidgets.
These only affect C/C++ code which needs to use the corresponding
libraries and headers. They don't affect "pure" Python or wxPython
code which doesn't require compilation, e.g. most of the wx GUI.
Currently, --with-python is required for the SWIG bindings,
--with-wxwidgets is required for xganim, and both are required for the
vdigit and nviz modules for the wx GUI.
The situation is the same as with Tcl/Tk: if you use --without-tcltk,
you still get gis.m, d.m, d.rast.edit etc, but you don't get v.digit,
NVIZ or the form library, which all contain C code which links against
libtcl/libtk.
