I get the following error trying to compile wxpython vdigit:
~/SRC/GRASS/grass_trunk/gui/wxpython/vdigit$ make
c++ -I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -g -O2 -fPIC -I/usr/include -I/usr/include/python2.4 -I/usr/include/python2.4 -fno-strict-aliasing -DNDEBUG -g -O2 -Wall -Wstrict-prototypes -I/usr/lib/wx/include/gtk2-unicode-release-2.8 -I/usr/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D_LARGEFILE_SOURCE=1 -D__WXGTK__ -pthread -DPACKAGE=\""grasslibs"\" -I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -o OBJ.i486-pc-linux-gnu/grass6_wxvdigit_wrap.o -c grass6_wxvdigit_wrap.cpp
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for Ada/C/ObjC but not for C++
grass6_wxvdigit_wrap.cpp: In function ‘PyObject* _wrap_DisplayDriver_UpdateSettings(PyObject*, PyObject*)’:
grass6_wxvdigit_wrap.cpp:11008: error: no matching function for call to ‘DisplayDriver::UpdateSettings(long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, int&)’
driver.h:210: note: candidates are: void DisplayDriver::UpdateSettings(long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long unsigned int, int)
make: *** [OBJ.i486-pc-linux-gnu/grass6_wxvdigit_wrap.o] Erreur 1
Any hints ?
Moritz
