[GRASS-dev] Compiling grass7_trunk in Funtoo
Hi devs!
Hope that some advanced Gentoo user is tuned-in. I am trying to compile
grass7_trunk in Funtoo. I managed to get a clean configuration of almost
everything required (except for LAPACK, BLAS and FFMPEG, all of which, if
I am no miss-taking, are not required).
The compilation ends-up like:
Started compilation: Sun Jul 7 10:24:41 EEST 2013
Errors in:
/osgeo/src/grass7_trunk/lib/python/ctypes
/osgeo/src/grass7_trunk/db/drivers/ogr
/osgeo/src/grass7_trunk/db/drivers/dbf
/osgeo/src/grass7_trunk/db/drivers/postgres
/osgeo/src/grass7_trunk/db/drivers/sqlite
/osgeo/src/grass7_trunk/db/drivers/odbc
/osgeo/src/grass7_trunk/db/drivers/mysql
/osgeo/src/grass7_trunk/gui/wxpython/vdigit
/osgeo/src/grass7_trunk/gui/wxpython/mapswipe
/osgeo/src/grass7_trunk/gui/wxpython/rlisetup
/osgeo/src/grass7_trunk/gui/wxpython/animation
/osgeo/src/grass7_trunk/gui/wxpython/dbmgr
/osgeo/src/grass7_trunk/gui/wxpython/psmap
/osgeo/src/grass7_trunk/gui/wxpython/iclass
/osgeo/src/grass7_trunk/gui/wxpython/gmodeler
/osgeo/src/grass7_trunk/man
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sun Jul 7 10:25:27 EEST 2013
make: *** [default] Error 1
Running make inside some of the above mentioned directories, tells that
some script was denied permissions to execute. I think it is a
Gentoo/Funtoo thing and has nothing to do with GRASS or missing
dependencies.
For example,
/osgeo/src/grass7_trunk/db/drivers/ogr $ make
VERSION_NUMBER=7.0.svn /osgeo/src/grass7_trunk/dist.x86_64-unknown-
linux-gnu/tools/g.html2man.py /osgeo/src/grass7_trunk/dist.x86_64-
unknown-linux-gnu/docs/html/grass-ogr.html
/osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
gnu/docs/man/man1/grass-ogr.1
/bin/sh: /osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
gnu/tools/g.html2man.py: Permission denied
make: *** [/osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
gnu/docs/man/man1/grass-ogr.1] Error 126
or
nik@localhost /osgeo/src/grass7_trunk/gui/wxpython/vdigit $ make
gnu/scripts/g.gui.vdigit: Permission denied
make[1]: *** [g.gui.vdigit.tmp.html] Error 1
rm g.gui.vdigit.tmp.html
make[1]: Leaving directory `/osgeo/src/grass7_trunk/gui/wxpython/vdigit'
make: *** [guiscript] Error 2
What should I watch out for?
Thank you, Nikos
On Sun, Jul 7, 2013 at 10:25 AM, Nikos Alexandris
<nik@nikosalexandris.net> wrote:
Hi devs!
You can check for optional functionality with ./configure --help.
AFAIK, BLAS and LAPACK are not used.
Errors in:
'make'.
Please note that...
You should really start with the first error
tells that
dependencies.
For example,
Check the permissions of
/osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/tools/g.html2man.py
or
/osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/scripts/g.gui.vdigit
Compilation should be done as normal user, not root. That means that
the source should be obtained and copied to its current location as
normal user. Maybe that helps.
Markus M
Nikos Alexandris:
> Errors in:
> 'make'.
Please note that...
So did I. Sorry, I skipped it in my post. The first error is:
/bin/sh: ./ctypesgen.py: Permission denied
make[1]: *** [OBJ.x86_64-unknown-linux-gnu/date.py] Error 126
make[1]: Leaving directory `/osgeo/src/grass7_trunk/lib/python/ctypes'
make: *** [default] Error 2
> tells that
> dependencies.
More upon this -- The partition I am running all this is mounted as
/dev/sda5 /osgeo ext4 auto,rw,exec,user 0 2
Trying in fist place to execute "./confiure" or "./configure --help"
wouldn't/wont do a thing. i.e.
./configure --help
bash: ./configure: Permission denied
Instructing, as I read somewhere (don't remember where!), "sh ./configure --
help" works fine! So, I think it is the same issue here too. For example,
./osgeo/src/grass7_trunk/lib/python/ctypes $ ./ctypesgen.py
bash: ./ctypesgen.py: Permission denied
So, in a similar way, instructing
python ./ctypesgen.py
Error: No header files specified
seems to work just fine.
My guess is that it's the same for all "Permission denied" errors. I need to
find a "global" solution and not going into handcrafting the scripts myself --
that wouldn't be the "right" way to do it.
> For example,
ls -lah g.html2man.py
-rwxr-xr-x 1 nik users 1.1K Jul 7 10:24 g.html2man.py
and "I" am in users,
groups nik
wheel audio cdrom video users
Hence, if I do
python /osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
  File "/osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
gnu/tools/g.html2man.py", line 48, in <module>
    main()
gnu/tools/g.html2man.py", line 15, in main
    infile = sys.argv[1]
IndexError: list index out of range
it looks like it's going.
[stuff remove]
Yes, I don't repeat this (anymore, since long ago). Trying to learn
Gentoo/Funtoo :slight_smile:
Danke Markus,
Nikos
Markus Metz:
have a look at lib/gmath/
Hamish
On Sun, Jul 7, 2013 at 12:07 PM, Hamish <hamish_b@yahoo.com> wrote:
Markus Metz:
They need to be compiled into GMATH when compiling the
i.spec.unmix (and i.spec.sam) Addons.
markusN
Nikos Alexandris wrote:
The first error is:
> > tells that some script was denied permissions to execute. I think it is
> > a Gentoo/Funtoo thing and has nothing to do with GRASS or missing
> > dependencies.
I used
cat /etc/fstab | grep osgeo
But it goes like
mount | grep sda5
/dev/sda5 on /osgeo type ext4
(rw,noexec,nosuid,nodev,commit=0)
Heh? Is the "user" option wrong?
Nikos
>The first error is:
> > > is a Gentoo/Funtoo thing and has nothing to do with GRASS or missing
> > > dependencies.
I used
2 --->%--
But it goes like
mount | grep sda5
/dev/sda5 /osgeo ext4 defaults,rw,exec
0 2
nik@localhost /osgeo/src/grass7_trunk $ mount | grep sda5
/dev/sda5 on /osgeo type ext4 (rw,commit=0)
That fixed all errors :slight_smile:
I guess I need to read what the consequences of auto and/or user options are
in fstab...
Nikos
