[GRASS-dev] Connection failure from v.krige to R (Win XP)
Hello Everyone,
I've tried to test new Kriging module. I've installed R tool (2.10.1) for
Win32 with packages gstat, spgrass6 and automap and also the necessary
connector rpy2. A description for setting up the rpy2 is not very clear, but
I finally placed it into C:\OSGeo4W\apps\Python25\Lib\site-packages and it
becomes visible for Grass. When v.krige was started, I got a Python version
conflict as the most recent rpy2 (2.0.8) msi installer contains its version
for Python 2.6 so I've downgraded rpy2 to 2.0.6. It helped.
However, just after invoking the Kriging module a system message appears:
'Are you sure you want to add the information in RHOME to the registry?'.
When Yes button is pressed, another message appears: 'Cannot import RHOME.
Error opening the file. There may be a disk or file system error.'
I reinstalled R from 'Program Files' to C:\R to avoid spaces in the path
(acc. to http://support.microsoft.com/kb/187316 ) but it didn't help. The
same result I got after setting the environment variable RHOME to
"C:\R\R-2.10.1".
Loading continues, but important buttons in the Kriging dialog are disabled.
A command output follows:
v.krige
Loading packages, please wait...
Loading required package: sp
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.6.3, released 2009/11/19
Path to GDAL shared files: C:/R/R-2.10.1/library/rgdal/gdal
Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
Path to PROJ.4 shared files: C:/R/R-2.10.1/library/rgdal/proj
Loading required package: XML
GRASS GIS interface loaded with GRASS version: 6.5.svn
and location: cr-wgs84
Loading required package: automap
(Sun Dec 27 10:56:55 2009) Command finished (445 sec)
When localized version is used, there are two extra lines at the beginning,
but it is not crucial I think:
During startup - Warning message:
Setting LC_CTYPE=cs_CZ failed
From the command log it is obvious some connection is established, but it is
not enough... Is it necessary to tune something a bit?
I use 6.5 version of Grass built from devel6 branch.
Jan
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
hi all, and sorry for top posting,
Jan, thanks for feedback. AFAIK no Windows testing has been done for
v.krige. I'll try to get it work on my XP box asap. If anyone has useful
tips about this issue, feel free to drop a line on v.krige's wiki page.
all the best,
Anne
Jan To¹ovský ha scritto:
Hello Everyone,
"C:\R\R-2.10.1".
v.krige
Jan
grass-dev mailing list
grass-dev@lists.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAks3dxEACgkQzZ3g4YwFFgYZNwCfe7E9Qs6pI2YmrtYq64UcBwUs
zGMAn3ogYCiJlT+Ga0z4BeYGDAjMrM7f
=qPe0
-----END PGP SIGNATURE-----
Several times I also met another Kriging issue. When entering the Kriging
dialog when a vector map was selected before this action via menu, I am
getting the following error and execution is stopped (no dialog appears)
v.krige input=isolines@honza
ERROR: Required parameter <column> was not set:
(Name of attribute column with numerical value to be interpolated).
Description:
Performs ordinary or block kriging.
Keywords:
(parameters info continues)
Maybe it is on purpose to process the selected map, (and that selected map
wasn't suited for this operation), but I would prefer selecting in the
dialog.
As this cannot be reproduced even with the same procedure later, I rather
think it could be a bug when something in the background is improperly
initialized.
Jan
