[GRASS-dev] convert to utm projection
How to convert a map in lat/long projection to UTM projection using grass gis?
Rashad
Hi Rashad,
You will have to create a new location for the same extent as your data in lat/long but this time specify the projection for the location as UTM. Then make this new location and mapset your working grass space. Now use v.proj OR r.proj to pull in the file from the lat/long location and mapset to the new location you just created. This should change the projection from lat/long to UTM.
Varun
Rashad
grass-user mailing list
grass-user@lists.osgeo.org
Complementing Varun response, take a look at the r.proj manual page
http://grass.ibiblio.org/grass65/manuals/html65_user/r.proj.html
Specially the Notes part, were it explains about the v.in.region trick
in order to set the region extent and resolution correctly
Daniel
gis?
Rashad
fyi in grass 6.5 and newer there is also the r.proj -p and -g flags which
make the v.in.region trick not really needed any more.
Hamish
I was not aware of the -p and -g flags
Nicer and nicer every time....
Hamish
