I'm running grass 8.3.1 on Ubuntu 22.04.3 in text mode ("grass --text ..."). g.proj is crashing on my system. Even a simple"g.proj --help" crashes after printing the command line options on console.
Core was generated by `g.proj -g'.
Program terminated with signal SIGSEGV, Segmentation fault. #0 0x00007f1eeb6a53fe in __GI___libc_free (mem=0x55c6c77e5bdd) at ./malloc/malloc.c:3368
3368 ./malloc/malloc.c: No such file or directory.
(gdb) bt #0 0x00007f1eeb6a53fe in __GI___libc_free (mem=0x55c6c77e5bdd) at ./malloc/malloc.c:3368 #1 0x00007f1ee76a7cb3 in osgeo::proj::common::UnitOfMeasure::~UnitOfMeasure() () from /lib/x86_64-linux-gnu/libproj.so.22 #2 0x00007f1eeb645a56 in __cxa_finalize (d=0x7f1ee7964000) at ./stdlib/cxa_finalize.c:83 #3 0x00007f1ee76a7737 in ?? () from /lib/x86_64-linux-gnu/libproj.so.22 #4 0x00007ffd20ceda90 in ?? () #5 0x00007f1eed52524e in _dl_fini () at ./elf/dl-fini.c:142
Backtrace stopped: frame did not save the PC
(gdb)
It is likely that this is a local environment problem and not a bug in g.proj. I've installed grass using standard Ubuntu package manager. The steps to reproduce are:
$ sudo apt install grass
$ grass -c EPSG:32643 --text $PWD/grassdata/PERMANENT
$ g.proj -g # crashes after printing the output
this is quite typical of a program linking to 2 different version of libproj at the same time, often when mixing repositories, where some components of one haven't been rebuilt against updated components of the other one
Check the output of "ldd /path/to/g.proj"
Even
Le 24/04/2024 à 18:54, Asim via grass-dev a écrit :
Hi
(gdb)
On 24/04/24 10:32 pm, Even Rouault via grass-dev wrote:
this is quite typical of a program linking to 2 different version of libproj at the same time, often when mixing repositories, where some components of one haven’t been rebuilt against updated components of the other one
ldd shows two versions of libproj (22 and 25) being linked / loaded: ldd /usr/lib/grass83/bin/g.proj | grep proj libgrass_gproj.8.3.so => /usr/lib/grass83/lib/libgrass_gproj.8.3.so (0x00007fac2322e000) libproj.so.25 => /usr/lib/x86_64-linux-gnu/libproj.so.25 (0x00007fac21600000) libproj.so.22 => /usr/lib/x86_64-linux-gnu/libproj.so.22 (0x00007fac1d200000) How do I get out of this? Asim
