[GRASS-dev] creating temporary mapsets in a parallelized python script
in a parallelized python script it is needed to do the parallelized jobs in
different mapsets as region settings are changed during calculations.
Any hints how to create temporary mapsets? Already existing pygrass /
pyscript functions?
thanks
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/creating-temporary-mapsets-in-a-parallelized-python-script-tp5260753.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On Mon, Apr 11, 2016 at 4:04 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
are you sure you need separate mapsets? You can also just use this:
env = os.environ.copy()
env['GRASS_REGION'] = grass.region_env(raster='elevation')
gscript.run_command('r.viewshed', ..., env=env)
Anna
pyscript functions?
thanks
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
Anna Petrášová wrote
On Mon, Apr 11, 2016 at 4:04 PM, Helmut Kudrnovsky &lt;
hellik@
&gt; wrote:
in
Anna
pyscript functions?
the idea of the script is to run (1) by python's multiprocessing for more
than 600 points.
IIRC (1) changes region during calculations, so several calculations may
interfere in regions settings.
(1)
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.basin/r.basin.py
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/creating-temporary-mapsets-in-a-parallelized-python-script-tp5260753p5260758.html
hellik@
&gt; wrote:
in
Anna
pyscript functions?
than 600 points.
I see, then it's easier to fix the script and use grass.use_temp_region
(1)
best regards
Helmut
On Mon, Apr 11, 2016 at 4:46 PM, Helmut Kudrnovsky &lt;
hellik@
hellik@
&gt; wrote:
jobs
in
Anna
pyscript functions?
than 600 points.
From the manual:
script.core.use_temp_region()[source]¶
Copies the current region to a temporary region with “g.region save=”, then
sets WIND_OVERRIDE to refer to that region. Installs an atexit handler to
delete the temporary region upon termination.
Does this function mean that: while concurrent r.basin runs on different
CPUs in the same mapset, there is no interefering by region settings change
interefering?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/creating-temporary-mapsets-in-a-parallelized-python-script-tp5260753p5260765.html
From the manual:
interefering?
Setting WIND_OVERRIDE (environmental variable) will happen for the current
process, so it won't affect other processes only subprocess which is
desired. (In your case, this won't work if you would use this function
outside of r.basin.) So yes, parallel processes (including g.region) won't
see WIND_OVERRIDE, so they will see and use the original computational
region.
The documentation describes just what happens in the background but not the
usage. Feel free to update that with your understanding.
Generally, use_temp_region should be used by any module which calls
g.region.
Vaclav
wenzeslaus wrote
On Mon, Apr 11, 2016 at 5:19 PM, Helmut Kudrnovsky &lt;
hellik@
From the manual:
then
change
interefering?
region.
the
g.region.
Vaclav
thanks for the hints and clarifications.
are there examples of the correct use of script.core.use_temp_region()
around?
I've found it in [1]:
124 # clone current region
125 grass.use_temp_region()
126
127 grass.run_command('g.region', res=panres, align=pan)
anything else to do?
[1]
https://trac.osgeo.org/grass/browser/grass/trunk/scripts/i.pansharpen/i.pansharpen.py#L124
thanks
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/creating-temporary-mapsets-in-a-parallelized-python-script-tp5260753p5260826.html
On 12/04/16 11:29, Helmut Kudrnovsky wrote:
hellik@
From the manual:
then
change
interefering?
region.
the
g.region.
Vaclav
around?
https://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library#Using_temporary_region_for_computations
Moritz
> interefering?
region.
The environment will be inherited by any child processes, so a
top-level script can use the same approach (but not use_temp_region()
itself) to use a different named region for each subprocess.
The main issue with use_temp_region() is that the clean-up function
uses the current value of the environment variable to determine which
region to delete.
This could be fixed by passing a lambda to atexit.register(), e.g.
def use_temp_region():
    name = "tmp.%s.%d" % (os.path.basename(sys.argv[0]), os.getpid())
    run_command("g.region", save=name, overwrite=True)
    os.environ['WIND_OVERRIDE'] = name
    atexit.register(lambda: run_command("g.remove", flags='f', quiet=True, type='region', name=name))
region to delete.
Perhaps we could decorate the function with contextmanager:
from contextlib import contextmanager
@contextmanager
def use_temp_region(**reg):
    original = region()
    try:
        reg = parse_command("g.region", save=name, overwrite=True, **reg)
        yield reg
    finally:
        # clean created variable and region
        print('WIND_OVERRIDE' in os.environ)
        os.environ.pop('WIND_OVERRIDE')
        # restore previous region
        for key in 'projection,zone,cells'.split(','):
            original.pop(key)
        run_command("g.region", **original)
and then use the function with:
run_command("g.region", flags='p')
print('=' * 30)
with use_temp_region(res=100) as tmp_region:
    print('=' * 30)
print('=' * 30)
All the best
Pietro
That's an option, but it complicates matters in the (probably more
common) case where you just want to use a single temporary region for
the entire script.
