CVS fetched just a while ago:
Errors in:
/home/fishoo/src/straight/grass6/vector/v.in.ogr
$ cd /home/fishoo/src/straight/grass6/vector/v.in.ogr
$ make
gcc -I/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/include
-g -O2 -I/usr/local/include -DPACKAGE=\""grassmods"\"
-I/home/fishoo/src/straight/grass6/dist.i686-pc-linux-gnu/include \ -o
OBJ.i686-pc-linux-gnu/main.o -c main.c main.c: In function `main':
main.c:632: error: `OFTDate' undeclared (first use in this function)
main.c:632: error: (Each undeclared identifier is reported only once
main.c:632: error: for each function it appears in.) make: ***
[OBJ.i686-pc-linux-gnu/main.o] Error 1
Last time I built on 05 July and all was OK. Since then in GRASS-COMMIT
Markus wrote, on 2006.07.06:
Modified Files:
main.c
Log Message:
'NULL' support activated for OFTInteger and OFTReal
Modified Files:
main.c
Log Message:
OFTDate added; OFTIntegerList hack polished
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
Errors in:
$ make
Modified Files:
main.c
Log Message:
Modified Files:
main.c
Log Message:
You need the most recent version of GDAL/OGR; the NEWS file at:
http://www.remotesensing.org/gdal/NEWS.html
says:
OGR 1.3.2 - Overview of Changes
OGRFeature:
- Added support for OFTDate, OFTTime and OFTDateTime field types.
- Also applied to a few drivers (shapefile, mysql, postgres)
As 1.3.2 has only been out a couple of months, I doubt that you will
be able to get an "official" package from your distribution vendor yet
(the 1.3.2 ebuild for Gentoo is still masked on all platforms).
On Fri, 7 Jul 2006 19:39:00 +0100
> Errors in:
> $ make
> gcc
> -o OBJ.i686-pc-linux-gnu/main.o -c main.c main.c: In function
> `main': main.c:632: error: `OFTDate' undeclared (first use in this
> function) main.c:632: error: (Each undeclared identifier is
> reported only once main.c:632: error: for each function it appears
> in.) make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
> GRASS-COMMIT Markus wrote, on 2006.07.06:
> Modified Files:
> main.c
> Log Message:
> Modified Files:
> main.c
> Log Message:
says:
OGRFeature:
types.
Oops. Time to update GDAL then (using 2006-02-10 for now). Thanks for
the information!
Maciek
> Errors in:
> $ make
> Modified Files:
> main.c
> Log Message:
> Modified Files:
> main.c
> Log Message:
says:
OGRFeature:
To make everybody happy, I have conditionalized OFTDate on
GDAL_VERSION_NUM >= 1320. It doesn't make the code more readable but
we can take it out in a couple of months.
Maciek, please test this before updating your GDAL installation.
On Sat, 8 Jul 2006 00:09:15 +0200
Done. v.in.ogr builds OK with GDAL 1.3.1.
Maciek
Good.
Now update your GDAL
You don't want to miss the improvements...
