using:
grass 7.0revision:54601
d.correlate is not working
To reproduce
d.mon wx0
d.correlate map=lsat5_1987_10,lsat5_1987_20
error:
GRASS_INFO_WARNING(25298,1): Illegal filename <landsat,lsat5_1987_20@landsat>. Character <,> not allowed.
GRASS_INFO_END(25298,1)
GRASS_INFO_WARNING(25314,1): Illegal filename <landsat,lsat5_1987_20@landsat>. Character <,> not allowed.
GRASS_INFO_END(25314,1)
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/misc.py", line 1358, in Notify
self.notify()
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/main.py”, line 290, in watcher
self.mapFrm.GetMap().GetLayersFromCmdFile()
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/main.py”, line 102, in GetLayersFromCmdFile
self.AddLayer(ltype = ltype, command = cmd, active = False, name = name)
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py”, line 1042, in AddLayer
active = active, hidden = hidden, opacity = opacity)
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py”, line 339, in init
active, hidden, opacity)
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py”, line 88, in init
self.SetType(ltype)
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py”, line 268, in SetType
raise GException((“Unsupported map layer type ‘%s’”) % ltype)
core.gcmd.GException: Unsupported map layer type ‘None’
Rashad
On Sat, Jan 12, 2013 at 10:43 AM, Rashad M <mohammedrashadkm@gmail.com> wrote:
using:
grass 7.0
revision:54601
To reproduce
d.mon wx0
error:
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_misc.py",
self.notify()
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/main.py", line
290, in watcher
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py", line
1042, in AddLayer
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py", line 339,
in __init__
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py", line 88,
in __init__
self.SetType(ltype)
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/render.py", line 268,
in SetType
raise GException(_("Unsupported map layer type '%s'") % ltype)
core.gcmd.GException: Unsupported map layer type 'None'
Some of d. commands are not supported yet in wxGUI but at least you
can try to add them as a command layer in Layer Manager, it is in the
'Add grid or vector overlays' (perhaps it should be 'Add miscellaneous
overlays').
Anna
Rashad
grass-dev mailing list
grass-dev@lists.osgeo.org
it worked using command layer
There should be some an option to use d.correlate in the other way too
d.mon wx0
d.correlate …
On Sun, Jan 13, 2013 at 9:49 PM, Anna Kratochvílová <kratochanna@gmail.com> wrote:
using:
grass 7.0
revision:54601
To reproduce
d.mon wx0
error:
self.notify()
290, in watcher
1042, in AddLayer
in init
in init
self.SetType(ltype)
in SetType
‘Add grid or vector overlays’ (perhaps it should be ‘Add miscellaneous
overlays’).
Anna
Rashad
Rashad
when a command is issued and if d.mon wx monitor is working it should be routed in a different way.
I noticed when d.correlate command is issued with wx montior ON, the command is not properly parsed.
could you tell when a command is issued within grass shell with Gui ON, where is get parsed?
so that i could try for a patch
On Mon, Jan 14, 2013 at 10:04 AM, Rashad M <mohammedrashadkm@gmail.com> wrote:
d.mon wx0
d.correlate …
Rashad
using:
grass 7.0
revision:54601
To reproduce
d.mon wx0
error:
self.notify()
290, in watcher
1042, in AddLayer
in init
in init
self.SetType(ltype)
in SetType
overlays’).
Anna
Rashad
Rashad
On Mon, Jan 14, 2013 at 5:46 AM, Rashad M <mohammedrashadkm@gmail.com> wrote:
It is strange that instead of d.correlate, there is written d.graph in
the command file used by d.mon (d.correlate calls d.graph). But I
don't know where the command is written into the command file (perhaps
g.parser?).
Anna
d.mon wx0
d.correlate .....
wrote:
> using:
> grass 7.0
> revision:54601
> To reproduce
> d.mon wx0
> error:
> File
> self.notify()
> line
> 290, in watcher
> line
> name)
> 1042, in AddLayer
> 339,
> in __init__
> 88,
> in __init__
> self.SetType(ltype)
> 268,
> in SetType
overlays').
Anna
> Regards,
> Rashad
Rashad
Rashad
