Dear all,
trying to use “db.connect -d” in GRASS 7.0 I see a not correct behaviour:
I previously set up a schema (e.g of a PostGIS DB) GRASS do not remove the schema, so I have to manually remove from VAR file. Perhaps there is a better way to remove it, but I think that -d option need to remove also the schema.
All the best,
R
