on the gpsdrive mailing list I was discussing using OpenStreetMap data
with GRASS's v.net modules to do shortest path routing.*
I received this comment which I don't know about:
> Unfortunately, the GRASS's dglib routines do not work on 64bit CPUs.
is there any truth to this? If so, what is needed to fix it?
Works fine for me. I downloaded your test data and ran several vector
commands against it (including v.net) without error. I've been running
GRASS 64bit for about a year.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
Paolo Cavallini
email+jabber: cavallini@faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
