[GRASS-dev] does r.composite respect a mask?
It is taking a VERY long time to run r.composite. It is a big map in its entirety. But only a part of the map falls within the MASK.
FWIW, I have the computational region set to match the MASK too.
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
r.composite doesn't do anything special with regard to the region or
mask.
A "sparse" map (with large null areas) should have some advantage over
a dense map, as the colour lookup optimises the case where a cell's
value matches the previous cell's value, and also checks for null
before other values.
It was really odd.
The original RGB channels were around 300 Mb each for the entire maps, with a resolution of 0.5m. Only about 1/4 was within the MASK and computational region. It took over 4 hours to run r. composite and produced a resulting map of over 5 Gb, but only for the area in the MASK and region.
When I reset the resolution to 1m, r.composite ran in a minute or so and produced a resulting map of 77Mb.
I’m OK with the 1m resolution I guess but the whole thing seemed strange.
Michael
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
mask.
