[GRASS-dev] Empty default answer
Is it correct leave empty a default answer in a module?
An example is in r.out.pov with zmod or objmod option
Thanks
Luca
According to programming manual 'answer' is not required. Also see
[1]. Maybe I am missing something but I can't see the options zmod and
objmod for that module.
Anna
[1] http://grass.osgeo.org/programming7/gislib.html#Answer_member_of_the_Flag_and_Option_structures
Thanks
Luca
grass-dev mailing list
grass-dev@lists.osgeo.org
(it is about v.out.pov):
http://grass.osgeo.org/grass64/manuals/html64_user/v.out.pov.html
I think that the empty ("") answers in
grass64/vector/v.out.pov/main.c
    58 zmod_opt = G_define_option();
    59 zmod_opt->key = "zmod";
    60 zmod_opt->type = TYPE_STRING;
    61 zmod_opt->required = NO;
    62 zmod_opt->answer = "";
    63 zmod_opt->description =
    64 "Modifier for z coordinates, this string is appended
to each z coordinate.\n"
    65 "\t\tExamples: '*10', '+1000', '*10+100', '*exaggeration'";
    66 objmod_opt = G_define_option();
    67 objmod_opt->key = "objmod";
    68 objmod_opt->type = TYPE_STRING;
    69 objmod_opt->required = NO;
    70 objmod_opt->answer = "";
    71 objmod_opt->description =
    72 "Object modifier (OBJECT_MODIFIER in POV-Ray documentation).\n"
    73 "\t\tExample: \"pigment { color red 0 green 1 blue 0 }\"";
should be removed.
should be removed.
I agree because the test is usually if (opt->answer), that is if
answer != NULL, which is true if the answer is "" = '\0', IOW, ""
would be treated as a valid answer.
Markus M
On Mon, Aug 20, 2012 at 11:17 AM, Markus Metz
Fixed in all branches and trunk.
