Mac OS X Yosemite, homebrew recipe.
| Checking for gdal-config... /usr/local/opt/gdal/bin/gdal-config
| rm: conftest.dSYM: is a directory
| checking whether to use libLAS... yes
| checking for liblas-config... /usr/local/opt/liblas/bin/liblas-config
| configure: error: *** Unable to locate libLAS library.
The config.log says:
| onfigure:6164: checking whether to use libLAS
| configure:6181: checking for liblas-config
| configure:6238: clang -o conftest -g -O2 -I/usr/local/opt/gettext/include -I/usr/local/Cellar/liblas/1.8.0/include -I/usr/local/include -I/usr/local/include -I/usr/local/include conftest.c -L/usr/local/Cellar/liblas/1.8.0/lib -llas -llas_c -L/usr/local/lib /usr/local/lib/libboost_program_options-mt.dylib /usr/local/lib/libboost_thread-mt.dylib /usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib /usr/local/lib/libgeotiff.dylib /usr/local/lib/libtiff.dylib 1>&5
| clang: error: no such file or directory: '/usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib'
| configure: failed program was:
| #line 6231 "configure"
| #include "confdefs.h"
| #include <liblas/capi/liblas.h>
| int main() {
| LASReader_Create("foo");
| ; return 0; }
| configure:6253: clang -o conftest -g -O2 -I/usr/local/opt/gettext/include -I/usr/local/Cellar/liblas/1.8.0/include -I/usr/local/include -I/usr/local/include -I/usr/local/include conftest.c -L/usr/local/Cellar/liblas/1.8.0/lib -llas -llas_c -L/usr/local/lib /usr/local/lib/libboost_program_options-mt.dylib /usr/local/lib/libboost_thread-mt.dylib /usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib /usr/local/lib/libgeotiff.dylib /usr/local/lib/libtiff.dylib 1>&5
| #line 6246 "configure"
| int main() {
| ; return 0; }
So the error is somewhere in the config logic and gdal?
gdal is installed - but /usr/local/Cellar/gdal/1.11.2_2
The installation works when I install without liblas.
Any suggestions on how to proceed?
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
The configure script runs "liblas-config --libs" to obtain the
libraries. liblas-config is saying that it needs
/usr/local/Cellar/gdal/1.11.1_2/lib/libgdal.dylib but the linker
complains that the file doesn't exist.
It may be that libLAS was built against a GDAL library which has since
been removed. In which case, you need to either restore that library
or re-build libLAS to use and existing version of GDAL (or without
GDAL; the dependency is optional).
Glynn Clements <glynn@gclements.plus.com> writes:
You are spot on! Great. Thanks a lot.
This solved the problem. I will add this to the test and to the WIKI
page.
South Africa
Skype: RMkrug
PGP: 0x0F52F982
