21 minutes and 37 seconds |
Martin Landa |
i.vi - be less verbose (cosmetics) git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69788 15284696-431f-4ddb-bdfa-cd5b030d7da7 |
System message:
OS X builds aren’t starting for private and public repositories. You can follow the updates here. Thank you for your patience.
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI Need help? Mail support! Choose who receives these build notification emails in your configuration file. |
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
