[GRASS-dev] Errored: GRASS-GIS/grass-ci#1792 (master - 3e29945)
Build #1792 has errored.
16 minutes and 57 seconds
Markus Neteler
3e29945 Changeset →
i.atcorr: Sentinel-2A support added using the Sentinel-2A Spectral Response Functions (S2A-SRF) from https://sentinel.esa.int/web/sentinel/user-guides/sentinel-2-msi/document-library
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70161 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
