In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: ma 29 jul 2024 10:15:45 WEST
make: *** [Makefile:71: default] Error 1
I proceeded as instructed:
$ cd /home/lads/git/grass/vector/v.profile
$ make
: && gcc -L/home/lads/git/grass/dist.x86_64-pc-linux-gnu/lib -L/home/lads/git/grass/dist.x86_64-pc-linux-gnu/lib -Wl,–export-dynamic -Wl,-rpath-link,/home/lads/git/grass/dist.x86_64-pc-linux-gnu/lib -Wl,-rpath,/usr/local/grass85/lib -o /home/lads/git/grass/dist.x86_64-pc-linux-gnu/bin/v.profile OBJ.x86_64-pc-linux-gnu/main.o OBJ.x86_64-pc-linux-gnu/processors.o -lgrass_vector.8.5 -lgrass_dbmiclient.8.5 -lgrass_dbmibase.8.5 -lgrass_gis.8.5 -lm
/usr/bin/ld: OBJ.x86_64-pc-linux-gnu/main.o: undefined reference to symbol ‘GEOSBufferParams_create’
/usr/bin/ld: /lib/x86_64-linux-gnu/libgeos_c.so.1: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make: *** […/…/include/Make/Module.make:18: /home/lads/git/grass/dist.x86_64-pc-linux-gnu/bin/v.profile] Error 1
This discussion at StackOverflow [0] indicates arguments missing to gcc. Compiling v.select returns the same error message.
Could this be something missing from my config? Or is it a real issue that should be reported?
So, if libsclean was the part that made it work, we might have to look at running it on distclean (if distclean is commonly used as a « super clean »).
$ make
On Mon, Jul 29, 2024 at 12:02 PM Edouard Choinière via grass-dev
Yes, "make distclean" is commonly used as a « super clean ».
Yes, that would be good. It is doing the « expected » behaviour for a more extensive clean, but looses the granularity meaning of « distclean » that only cleans the dist folder, and libsclean only cleans the compiled grass libs.
Speculating here: Maybe if grass is compiled and installed, not compiling the libs from the repo results in having the system available libs instead. Is there a way to verify that hypothesis?
Something similar happened during the code sprint, when after using libsclean made the next builds work, but I wasn’t able to reproduce like expected afterwards..
Edouard Choinière
