[GRASS-dev] Extract vector features from external PostGIS layer without building topology
Dear devs,
I am looking for a confirmation that the following is _not_ possible:
v.external -b input="PG:host=somehost user=someuser dbname=somepgdb" layer=somemaplayer
then
v.extract input=somemaplayer output=somemaplayer_extract where="some sql query"
Building topology is required, here. Right?
Thank you, Nikos
2017-08-06 8:38 GMT+02:00 Nikos Alexandris <nik@nikosalexandris.net>:
layer=somemaplayer
then
query"
currently `v.extract` requires topology [1]. It would be possible to
modify it in order to operate also on level 1 (no topology). At least
for points it would make sense. For areas you always need topology
built. Ma
[1] https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.extract/main.c#L188
À Dimanche 6 août 2017, Martin Landa a écrit :
> layer=somemaplayer
> then
> query"
built. Ma
Than you Martin,
N
