[GRASS-dev] fixes for Windows
Colin,
With help from Glynn Clements, I was able to fix the bug that prevented NVIZ for TclTk from running from the wxPython menu. I also added the TclTk digitizer to the menu. So now Windows users will have easy access to 3D rendering and digitizing (without requiring that msys be loaded) until the wxPython equivalents can be implemented in Windows.
Michael
____________________
C. Michael Barton
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Michael,
Great to have that bug finally fixed. Helmut should be putting another
release together in the next week so it will be in there.
-Colin
On Tue, Dec 15, 2009 at 1:49 AM, Michael Barton <michael.barton@asu.edu> wrote:
Colin,
Michael
C. Michael Barton
Phone: 480-965-6262
Fax: 480-965-7671
Windows.
FWIW, with a bit of hacking, I managed to get vdigit and nviz to
compile with MinGW, but both fail at the linking step with a
"ld.exe has encountered a problem ..." dialog. That's as far as I have
got so far.
Issues:
1. The lack of python-config and wx-config scripts. I just created
scripts which give the right answers for my system.
2. The setup.py build system passes the Platform.make settings to gcc
without going through the shell, which means that the MSys-style
pathnames don't get translated to valid Windows pathnames.
I got around this by inserting the following into setup.py:
  mounts = [('/c/', 'c:/'),
      ('/usr/', 'c:/msys/1.0/'),
      ('/', 'c:/msys/1.0/')]
  def from_msys(d):
      for src, dst in mounts:
    if d.startswith(src):
        d = dst + d[len(src):]
        break
      d = d.replace('/', '\\')
      return d
  inc_dirs = map(from_msys, inc_dirs)
  lib_dirs = map(from_msys, lib_dirs)
Cygwin has the "cygpath" utility for this, but I couldn't find
anything similar for MSys.
3. Python.h defines HAVE_PUTENV and HAVE_FTIME, which causes the
preprocessor to emit "... redefined" warnings. These are only
warnings, but AC_CHECK_HEADERS fails if anything is written to stderr.
4. setup.py doesn't consider enough variables, e.g. CPPFLAGS and
INCLUDE_DIRS aren't used. But then the whole thing with trying to
parse the *.make files is broken (e.g. "make ... VAR=val" doesn't
work).
5. The definition of PACKAGE needs the backslashes, i.e.:
  macros = [('PACKAGE', '\\"grasslibs\\"')]
(but this might break other platforms).
BTW, vdigit uses _(...) but doesn't include glocale.h, so this will
use wxWidgets' _(...) macro from <wx/intl.h>, not GRASS'.
6. A couple of minor bugs:
vdigit/digit.cpp expects _CPPRTTI to be defined if _WIN32 is defined,
but this should only be done for MSVC.
vdigit/driver.cpp uses getpid() but doesn't include <unistd.h>.
Thanks Glynn.
I hope that someone is able to help you with this. Sounds like it is getting close.
Michael
Windows.
got so far.
Issues:
  def from_msys(d):
        break
      return d
work).
2009/12/16 Glynn Clements <glynn@gclements.plus.com>:
   macros = \[\(&#39;PACKAGE&#39;, &#39;\\\\&quot;grasslibs\\\\&quot;&#39;\)\]
Then I am getting (GNU/Linux)
<command-line>: warning: missing terminating " character
Could this be avoided?
Should be fixed in r40030.
Martin
I thought that something like that might happen. If the existing code
is correct for Linux, a changed version probably wouldn't be.
  if sys.platform == "win32":
      package = '\\"grasslibs\\"'
  else:
      package = '"grasslibs"'
  macros = [('PACKAGE', package)]
2009/12/17 Glynn Clements <glynn@gclements.plus.com>:
   if sys\.platform == &quot;win32&quot;:
       package = &#39;\\\\&quot;grasslibs\\\\&quot;&#39;
   else:
       package = &#39;&quot;grasslibs&quot;&#39;
   macros = \[\(&#39;PACKAGE&#39;, package\)\]
sure, done in r40036.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
