[GRASS-dev] For OS X: homebrew tap to install and test grass 7.1 from HEAD
Hi
This is for OS X.
I have created a homebrew [1] tap to make installing and testing of GRASS
7.1 (HEAD from svn) easier.
You can find it here:
https://github.com/rkrug/homebrew-experimental
It uses homebrew [1] and installs
1) homebrew
2) North Carolina sample data set
The grass-71 recipe includes a test
| brew test grass-71
which uses the dataset to run unit tests as suggested by Vaclav (with
paths adjusted according to the location of the sample dataset as
installed using homebrew):
| ./bin.../grass71 ~/grassdata/nc_spm_08/PERMANENT/ \
| --exec python -m grass.gunittest.main \
| --location nc_spm_08 --location-type nc
These are my first steps into homebrew - so please check the recipes and
let me know if something does not work (preferably via the issue tracker
if it is a bug so that nothing gets lost).
Hope this helps,
Rainer
Footnotes:
[1] http://brew.sh
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
