[GRASS-dev] G70: Link to PG database issue (wxGUI)
I tried to connect to a PostGIS database but in the wxGUI tool (File
-> Link external data -> Link external vector data) the "PostgreSQL"
selector offers only a greyed out filed (editable for SQLite etc).
I had recompiled my installation with PG support:
db.connect help
Parameters:
    driver Name of database driver
             options: ogr,pg,sqlite,dbf <<-- ok
             default: sqlite
so I don't understand why the wxGUI link tool silently suppressed
PostgreSQL here (it could tell me at least why :slight_smile:
Any suggestions?
thanks
2014-05-24 0:36 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
do you have any PG database accessible?
db.database dri=pg
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
On Sat, May 24, 2014 at 9:28 AM, Martin Landa <landa.martin@gmail.com> wrote:
Aha...
db.databases driver=pg
DBMI-PostgreSQL driver error:
Unable to connect to Postgres:
FATAL: role "neteler" does not exist
OK, sure - the PG user name is different here. Would be cool to pop up
this error message in the wxGUI somehow to get on the right track
(maybe when the user attempts to select PG in the dropdown list?).
My scope is to fetch some points from PostGIS with v.external while
keeping the DB settings using SQLite.
2014-05-24 10:06 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
done in r60461 (wxGUI error), I have also added note about db.login
r60462 (trunk only). Ideally the wxGUI dialog should contain
user/passwd widget to enter the values directly without need to launch
db.login explicitly. Please feel free to fill enhancement ticket.
Martin
2014-05-24 22:40 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
related - in r60465-6 I fixed `db.databases` to understand settings
from `db.login`.
$ db.databases dri=pg
fe_sendauth: no password supplied
ERROR: Unable to list databases. Try to define correct connection
settings by db.login.
$ db.login dri=pg user=martin pass=xxx
template1
template0
postgres
Martin
Hi Martin,
On Sat, May 24, 2014 at 11:12 PM, Martin Landa <landa.martin@gmail.com> wrote:
ok, perhaps once the rest is there.
from `db.login`.
Tested and works in the wxGUI - the message pops up. Thanks.
BTW, partially related:
http://trac.osgeo.org/grass/ticket/1951
Sidenote:
I wonder how to avoid to specify the pw on command line. In r39879 the
interactive query was removed.
Indeed, I would even prefer to scramble the pw and **** when typing it
into the GUI window which would be done with
http://wxpython.org/Phoenix/docs/html/TextCtrl.html
TE_PASSWORD: The text will be echoed as asterisks.
No idea if a flag could be added to enable this (perhaps a new
G_define_option() for password strings?
template1
template0
postgres
While this is now working also here, in terms of the original issue I
wonder if it is needed to switch the DB settings for the mapset when
"only" trying to link to one PostGIS vector map (so a kind of mixed
use).
2014-05-25 12:24 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
use).
running `db.login` doesn't mean that you switch DB settings. It just
allows you to defined user/password for given driver, nothing else.
$ db.connect -p
driver: sqlite
database: /opt/grassdata/gis1-sjtsk/g6/sqlite/sqlite.db
OK, something is missing.
$ db.login dri=pg user=xxx passwd=yyy
template1
template0
Default DB settings untouched...
$ db.connect -p
driver: sqlite
schema:
group:
Martin
On Sun, May 25, 2014 at 7:57 PM, Martin Landa <landa.martin@gmail.com> wrote:
use).
ok, good! I got confused by the actual manual of db.login:
"DESCRIPTION
db.login sets the user name and optionally also a password for the
connection to the selected database through the DB driver.
This should be expanded (good wording welcome).
