Just rebuilt with:
# regexp {nsres= *([0-9]+)} $region dummy oldres1
# regexp {ewres= *([0-9]+)} $region dummy oldres2
# regexp {rows= *([0-9]+)} $region dummy vrows
# regexp {cols= *([0-9]+)} $region dummy vcols
set reglist [split $region "\n"]
foreach line $reglist {
set line [string trim $line]
set key [lindex [split $line "="] 0]
switch $key {
nsres {set oldres1 [lindex [split $line "="] 1]}
ewres {set oldres2 [lindex [split $line "="] 1]}
rows {set vrows [lindex [split $line "="] 1]}
cols {set vcols [lindex [split $line "="] 1]}
Here is the new error (upon starting GmAnim):
invalid command name "Proc"
while executing
"Proc GmAnim::do_run {} {
# procedure that displays maps in an animation and controls the animation
global loop
global swing
global a..."
(file "/Applications/GRASS-6.3.app/Contents/MacOS/etc/gm/animate.tcl" line 635)
invoked from within
"source /Applications/GRASS-6.3.app/Contents/MacOS/etc/gm/animate.tcl"
(in namespace eval "::" script line 1)
invoked from within
"namespace eval :: $auto_index($name)"
(procedure "auto_load" line 13)
invoked from within
"auto_load $name [uplevel 1 {::namespace current}]"
(autoloading "GmAnim::main")
invoked from within
"GmAnim::main"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.topf.tb1.bbox4.b0"
(command bound to event)
On Oct 1, 2007, at 9:17 PM, Michael Barton wrote:
Kirk,
You seem to be missing a line (maybe my fault). Note the line defining
reglist.
Michael
switch $key {
On 10/1/07 6:36 AM, "Kirk Wythers" <kwythers@umn.edu> wrote:
On Sep 30, 2007, at 11:23 PM, Michael Barton wrote:
Well, after asking for help, I figured out how to this without the
dread
regexp ;-). This might even be a bit better routine.
Anyway, I can't commit this because I'm out of town, but if anyone
wants to
try it, you need to change lines in procedure GmAnim::main (module
animate.tcl). Replace the commented lines with the uncommented
lines below.
switch $key {
Michael,
Thanks for the email. I made the following changes but ended up with
a new error. I might have altered the wrong file. Here is what I tried.
From the file ~/src_intel/grass-6.3.cvs/gui/tcltk/gis.m/animate.tcl
# set initial canvas geometry to match region
if {[catch {set region [exec g.region -ugp]} error]} {
Gm::errmsg $error
switch $key {
New error when startring up GmAnim.
can't read "reglist": no such variable
while executing
"foreach line $reglist {
switch $key {
nsres {..."
(procedure "GmAnim::main" line 28)
invoked from within
"GmAnim::main"
invoked from within
"uplevel \#0 $cmd"
invoked from within
Perhaps this is not what you intended?
Kirk
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Kirk Wythers wrote:
Just rebuilt with:
switch $key {
while executing
global loop
global swing
global a..."
That's something which has occurred at your end. The source file in
CVS has "proc" in lower case.
Can you clarify? Are you saying that even after "make distclean" and
"configure", the problem with d.m.html doesn't always occur?
No it doesn't, I was clarifying that before the error occurred the first time I had done "make distclean".
Now I can compile with no errors but
Generated HTML docs in ../dist.i686-apple-darwin8.10.1/docs/html/index.html
Following modules are missing the 'description.html' file in src code:
d.m
GRASS GIS compilation log
Started compilation: Tue Oct 2 15:59:30 CEST 2007
Errors in:
No errors detected.
Thanks to everyone who has responded to my GmAnim problem. Here is the latest.
Suspecting that I had other issues in the src, I dumped the source, re-downloaded new source from cvs, and ran update -dP.
Then I commented out the regex and added Michael's code:
Gm::errmsg $error
#regexp {nsres= *([0-9]+)} $region dummy oldres1
#regexp {ewres= *([0-9]+)} $region dummy oldres2
#regexp {rows= *([0-9]+)} $region dummy vrows
#regexp {cols= *([0-9]+)} $region dummy vcols
switch $key {
Presently GmAnim runs (using the same 30s raster from the worldclim database). However I do notice that several of the buttons on the animation window are broken, including the "exit" button, which gives this error:
WARNING: <tmpanimregion541> nothing removed
while executing
"exec g.remove region=$tmpregion --q"
(procedure "GmAnim::cmd_exit" line 21)
invoked from within
"GmAnim::cmd_exit"
As an odd sidenote, the older version of GmAnim (before the animation window was updated to have buttons on the top of the window) worked fine with:
the latest.
Sorry for a stupid comment: why not working with patches
against CVS? The current approach seems to be a bit "lossy".
patch/diff is fairly easy to use (see SUBMITTING in the main
source code directory).
View this message in context: http://www.nabble.com/ganim-troubles-in-latest-cvs-tf4535542.html#a13000761
Sent from the Grass - Dev mailing list archive at Nabble.com.
No worries on the comment. I'll look at SUBMITTING.
My only excuse is that on a fast connection and a fast processor, the "lossy" solution takes less than 10 minutes and then I'm sure that all of my potential personal screw ups are gone
this error:
while executing
invoked from within
"GmAnim::cmd_exit"
The warning is just that, not an error. But I don't know what is causing
this. I'll look into it.
fine with:
The very first version that was disseminated, was written by Glynn as a
prototype TclTk replacement for Xganim. When I incorporated it into the
overall TclTk GUI, I had to change aspects of how it operated--though not
this part. These statements work fine with integer-level resolutions (e.g.,
1m, 30m), but seem to have problems with resolutions that are floating
point. I'm sure that the regexp statements could be changed to deal with FP
data, but I don't know how to do it. So I accomplished this by another
route.
Michael
phone: 480-965-6213
fax: 480-965-7671
d.m
That message indicates that d.m.html was found but is missing the
DESCRIPTION section.
FWIW, I've since changed the way that the HTML files are generated;
pattern rules are no longer used. I don't know if this will actually
fix the problem, though.
