Seems, that we need to go back to old, (ugly) code, if nobody comes up
with better solution. See attached patch. Somebody test && commit.
I tested it locally and it works on my one system ( I don't have access to the other today ). I don't have cvs access so I can't commit it.
Maris.
2007/10/12, Trevor Wiens <twiens@interbaun.com>:
> On two systems I've tried, choosing point symbols results in a format of
> box@basic
> instead of
> basic / box
> As a result, the display of points fails
> T
> Trevor Wiens
> The significant problems that we face cannot be solved at the same
> level of thinking we were at when we created them.
> (Albert Einstein)
> grass-dev mailing list
> grass-dev@grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Trevor Wiens
(Albert Einstein)
I just ran into this too. I'm not sure whether it's only a product of my
changes of some weeks back to make multiple selections functional (there was
quite a bit of broken code that I fixed) or a combination of that and some
other changes elsewhere in GRASS. I thought I'd tested all aspects of
select.tcl, including symbol selection, but maybe I missed this part.
There is a special procedure for symbols that was inserted into select.tcl
awhile back (>1yr). Some of this may be what broke multi-selection code, but
I can't be sure of that. Now that multi-selection functionality is working
again, I'll look to see what is causing this problem with symbol selection.
It looks relatively simple to fix--but looks can sometimes be deceiving.
Michael
On 10/12/07 3:22 PM, "Trevor Wiens" <twiens@interbaun.com> wrote:
On Fri, 12 Oct 2007 09:25:13 +0300
"Maris Nartiss" <maris.gis@gmail.com> wrote:
Director of Graduate Studies
Arizona State University
