[GRASS-dev] gis.m, thematic layer: You must open a display monitor
Michael,
I am seeing a new error for d.vect.thematic. Trying to display a thematic layer fails with the message: *** You must open a display monitor ***
I can reproduce this with any spearfish vector layer.
The problem seems to be in lines 336-345 where it checks for the existance of an x-monitor. It seems to do this unconditionally, so even if you run it from the GIS Manager it still checks and fails if there is not monitor.
I can't find anything recent in the commit logs that would explain this, so before trying to go deeper into it, I wanted to know if you had an idea why this is suddenly happening.
Moritz
I have no idea. Perhaps I'm imagining things, but I swear that I'm seeing a
LOT more of these messages recently--with their deleterious effects on
scripting. Hamish says they've been there all along. I'm suspecting that the
code for the message has existed, but they did not get parsed for some
reason. But that is just speculation.
Michael
On 2/13/07 6:19 AM, "Moritz Lennert" <mlennert@club.worldonline.be> wrote:
Michael,
monitor ***
not monitor.
Moritz
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Well in this case, there is a change by Daniel dated Jan. 28 which might be linked:
- Added quotes in occurences of 'if [ -z "$var" ]'
But reverting back to no quotes gives the same error message.
Looking at the logic, I don't actually understand how this worked before. As I said, IIUC the x-mon test seems to be done whether you are using GIS Manager or not. But under GIS Manager there should be no x-mon...
Conditonalising the check as follows:
if [ "$GIS_FLAG_S" -eq 0 ] ; then
   if [ -z "$currmon" ] ; then
         echo ""
         echo "*** You must open a display monitor ***"
         echo ""
         cleanup
         exit 2
   fi
fi
makes the error message go away, but I get a new one:
Usage: /usr/lib/grass/etc/mon.select monitor_name
This time, however, the map and legend are displayed correctly (without the "fix" only the legend is displayed). I can get this second error message to go away by commenting line 862:
# d.mon select=$currmon
This comes from the fact that $currmon is empty in GIS Manager. Again, I don't understand why we have to deal with d.mon here if we are in the GIS Manager...and why this did not cause any problems before.
Moritz
Michael
Michael,
monitor ***
not monitor.
Moritz
phone: 480-965-6213
fax: 480-965-7671
There should be a flag to send output to the gis manager. This flag should
cause this conditional to be skipped.
Michael
be linked:
         echo ""
         echo ""
         cleanup
         exit 2
   fi
fi
Moritz
Michael
Michael,
monitor ***
not monitor.
Moritz
phone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
The flag is $GIS_FLAG_S:
On line 860ff you have this:
# reset rendering for GUI use
      if [ "$GIS_FLAG_S" -eq 1 ] ; then
fi
In my understanding, unless someone works in parallel with GIS Manager and x-mons, $currmon will be empty and this is where this error message comes from.
Maybe it's just a problem of an unequal number of if and fi calls...
But I don't have the time to go into the file in detail now...sorry.
Moritz
Michael
be linked:
         echo ""
         echo ""
         cleanup
         exit 2
   fi
fi
Moritz
Michael
Michael,
monitor ***
not monitor.
Moritz
phone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
Hi Michael, Moritz.
I'll look at it when I get home. That's in about 10 hours.
Daniel.
BTW did you try d.vect.thematic for >20 categories? Legends now do
have their nice cut in the middle.
fi
comes from.
Moritz
> Michael
>> be linked:
>> echo ""
>> echo ""
>> cleanup
>> exit 2
>> fi
>> fi
>> Moritz
>>> Michael
>>>> Michael,
>>>> monitor ***
>>>> not monitor.
>>>> Moritz
>>> phone: 480-965-6213
>>> fax: 480-965-7671
> phone: 480-965-6213
> fax: 480-965-7671
-- Daniel Calvelo Aros
Sorry for the awful delay. I think the problems with d.mon select are
resolved; please test. I also made the legend cuts work for ps.map and
display managers. In CVS.
Daniel.
On 2/13/07, Daniel Calvelo <dca.gis@gmail.com> wrote:
Hi Michael, Moritz.
Daniel.
> fi
> comes from.
> Moritz
> > Michael
> >> be linked:
> >> echo ""
> >> echo ""
> >> cleanup
> >> exit 2
> >> fi
> >> fi
> >> Moritz
> >>> Michael
> >>>> Michael,
> >>>> monitor ***
> >>>> not monitor.
> >>>> Moritz
> >>> phone: 480-965-6213
> >>> fax: 480-965-7671
> > phone: 480-965-6213
> > fax: 480-965-7671
I get the following error. The line
format [G_msg "Legend for Map %d, %s"] $mon, $opt($id,1,map)
seems to be the problem.
Moritz
expected integer but got "1,"
     while executing
"format [G_msg "Legend for Map %d, %s"] $mon, $opt($id,1,map)"
     (procedure "GmThematic::tlegend" line 11)
     invoked from within
"GmThematic::tlegend $mon $id"
     (procedure "GmThematic::display" line 72)
     invoked from within
"GmThematic::display $node $mod"
     ("thematic" arm line 2)
     invoked from within
"switch $type {
         group {
             GmGroup::display $node $mod
    raster {
      GmRaster::display $node $mod
    labels {
      GmLabels::disp..."
     (procedure "GmTree::display_node" line 7)
     invoked from within
"GmTree::display_node $n $mod"
     (procedure "GmGroup::display" line 22)
     invoked from within
"GmGroup::display "root" $mod"
     (procedure "MapCanvas::runprograms" line 64)
     invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
     (procedure "MapCanvas::drawmap" line 38)
     invoked from within
"MapCanvas::drawmap $mon"
     (procedure "MapCanvas::display_server" line 9)
     invoked from within
     ("after" script)
Daniel.
Hi Michael, Moritz.
Daniel.
> fi
> comes from.
> Moritz
> > Michael
> >> be linked:
> >> echo ""
> >> echo ""
> >> cleanup
> >> exit 2
> >> fi
> >> fi
> >> Moritz
> >>> Michael
> >>>> Michael,
> >>>> monitor ***
> >>>> not monitor.
> >>>> Moritz
> >>> phone: 480-965-6213
> >>> fax: 480-965-7671
> > phone: 480-965-6213
> > fax: 480-965-7671
Sorry, copy-paste introduced typo by me. Attached patch should fix
problem. Please, test and commit.
Maris.
2007/3/2, Moritz Lennert <mlennert@club.worldonline.be>:
Moritz
     while executing
     invoked from within
     invoked from within
     invoked from within
"switch $type {
         group {
    raster {
    labels {
      GmLabels::disp..."
     invoked from within
     invoked from within
     invoked from within
     invoked from within
     invoked from within
     ("after" script)
(attachments)
thematic.typo.patch (675 Bytes)
Thanks, that was it.
Committed to CVS.
Moritz
Maris.
Moritz
     while executing
     invoked from within
     invoked from within
     invoked from within
"switch $type {
         group {
        raster {
        labels {
            GmLabels::disp..."
     invoked from within
     invoked from within
     invoked from within
     invoked from within
     invoked from within
     ("after" script)
Index: gui/tcltk/gis.m/thematic.tcl
RCS file: /home/grass/grassrepository/grass6/gui/tcltk/gis.m/thematic.tcl,v
retrieving revision 1.25
diff -u -u -r1.25 thematic.tcl
--- gui/tcltk/gis.m/thematic.tcl 22 Feb 2007 15:45:29 -0000 1.25
+++ gui/tcltk/gis.m/thematic.tcl 2 Mar 2007 09:39:41 -0000
@@ -619,7 +619,7 @@
    if { [winfo exists .tlegend($mon,$id)] } {return}
- set legendtitle [format [G_msg "Legend for Map %d, %s"] $mon, $opt($id,1,map)]
+ set legendtitle [format [G_msg "Legend for Map %d, %s"] $mon $opt($id,1,map)]
   toplevel .tlegend($mon,$id)
     wm title .tlegend($mon,$id) $legendtitle
Thanks much Moritz
Michael
Committed to CVS.
Moritz
Maris.
Moritz
     while executing
     invoked from within
     invoked from within
     invoked from within
"switch $type {
         group {
        raster {
        labels {
            GmLabels::disp..."
     invoked from within
     invoked from within
     invoked from within
     invoked from within
     invoked from within
     ("after" script)
@@ -619,7 +619,7 @@
$opt($id,1,map)]
$opt($id,1,map)]
phone: 480-965-6213
fax: 480-965-7671
