I can confirm it on Mac. A simple expression like this:
r.mapcalc diff=elev_ned10m_bil-elev_ned10m_bic
runs in linux shell, but fails in wxgui command console and
in the map calculator. I am getting the same error
File "/Users/helena/grassrel6/grass64_release/dist.i386
-apple-
darwin10.8.0/etc/wxpython/gui_modules/mcalc_builder.py",
line 453, in OnMCalcRun
self.log.RunCmd(cmd, onDone = self.OnDone)
-apple-darwin10.8.0/etc/wxpython/gui_modules/goutput.py",
line 521, in RunCmd
task = menuform.GUI(show = None).ParseCommand(command)
-apple-darwin10.8.0/etc/wxpython/gui_modules/menuform.py",
line 1732, in ParseCommand
blackList = _blackList)
-apple-darwin10.8.0/etc/python/grass/script/task.py", line
460, in parse_interface
tree = etree.fromstring(get_interface_description(name))
File "/System/Library/Frameworks/Python.framework/Versions
/2.6/lib/python2.6/xml/etree/ElementTree.py", line 964, in
XML
return parser.close()
/2.6/lib/python2.6/xml/etree/ElementTree.py", line 1254, in
close
self._parser.Parse("", 1) # end of data
xml.parsers.expat
ExpatError
no element found: line 1, column 0
Helena
Helena Mitasova
Associate Professor
Department of Marine, Earth, and Atmospheric Sciences
2800 Faucette Drive, Rm. 1125 Jordan Hall
North Carolina State University
Raleigh, NC 27695-8208
hmitaso@ncsu.edu
On Jan 12, 2012, at 5:34 PM, Helmut Kudrnovsky wrote:
A third and final release candidate of GRASS 6.4.2 is now available.
Please join us in testing this release candidate for the final release.
the wx-r.mapcalculator isn't working, tested with a simple calculation
elevation@PERMANENT / elevation@PERMANENT
it's in WinGRASS-6.4.2RC3-1-Setup, osgeo4w-WinGRASS-6.4.2RC3 and also
in WinGRASS-6.5.svn:
File "C:\OSGeo4W\apps\grass\grass-6.4.2RC3\etc\wxpython\gu
i_modules\mcalc_builder.py", line 453, in OnMCalcRun
i_modules\goutput.py", line 521, in RunCmd
File "c:/osgeo4w/usr/src/release_20120112_grass_6_4_2RC3/d
ist.i686-pc-mingw32/etc/wxpython/gui_modules/menuform.py",
ist.i686-pc-mingw32/etc/python/grass/script/task.py", line
File
"c:\OSGeo4W\apps\Python25\lib\xml\etree\ElementTree.py",
line 964, in XML
File
line 1254, in close
xml.parsers.expat
ExpatError
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2RC3-released-tp7180383p7182079.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
grass-dev mailing list
grass-dev@lists.osgeo.org
