Markus N wrote:
... since Hamish currently backports more from dev6, I'll
postpone RC3 for some hours or whatever suitable.
thanks, I'm done for now, but there's one outstanding difference
between relbr64 and devbr6 for r.watershed that MarkusM might
have a look at (see below). I mostly focused on display/ and
raster/ where most of my changes are. scripts/ and ps/ should
be ok. I tried to just focus on either bugs or simple changes
which were made long long ago so have had tons of testing
already.
Using kdiff3 I notice a few differences in the DB drivers, I
think some extra driver closings and debug experiments were
put into devbr6 for testing zombie dbf.exe errors in WinGrass.
It's probably still worth comparing the two builds on wingrass
to see if they actually help -- aka it will be good to know
what commit definitively fixes it as opposed to guessing that
it might be ok now.
A number or nviz diffs exist too, maybe should be looked at at
some point by the authors. (seems to be Tcl 8.6 api updates, +)
kompare/kdiff3/meld were all a bit annoying to set up with
regex filters to avoid $Date$, OBJ.*, .svn/, dist.*, etc.,
I should write down some notes in the wiki while it's still
fresh in my mind, but it's too late for today.
-->so I'm go for RC3 as soon as r.watershed gets looked at.
regards,
Hamish
https://trac.osgeo.org/grass/changeset/54765
https://trac.osgeo.org/grass/changeset/54766
a current diff on raster/r.watershed/ram/do_cum.c, the first
one just seems to be a speedup, the second changes behavior.
--- relbr_6_4/raster/r.watershed/ram/do_cum.c 2013-02-20 17:45:31.877625578 +1300
+++ grass65/raster/r.watershed/ram/do_cum.c 2013-04-12 17:52:36.990693417 +1200
@@ -26,8 +26,8 @@
aspect = asp[this_index];
seg_index_rc(alt_seg, this_index, &r, &c);
if (aspect > 0) {
- dr = r + asp_r[ABS(aspect)];
- dc = c + asp_c[ABS(aspect)];
+ dr = r + asp_r[aspect];
+ dc = c + asp_c[aspect];
else
dr = dc = -1;
@@ -149,9 +149,9 @@
FLAG_SET(worked, r, c);
- if (aspect > 0) {
- dr = r + asp_r[aspect];
- dc = c + asp_c[aspect];
+ if (aspect) {
+ dr = r + asp_r[ABS(aspect)];
+ dc = c + asp_c[ABS(aspect)];
else
dr = dc = -1;
