personally I would like to see GRASS 7.2.0 released somewhere in July.
Do you think that it's realistic? If so I would suggest roadmap
bellow:
1) to create releasebranch 7_2 ASAP (in the beginning of May)
1) soft freeze in releasebranch_7_2 ~ 16 May
2) GRASS 7.2.0RC1 ~ 16 June
3) GRASS 7.2.0RC2 ~ 30 June
4) GRASS 7.2.0 ~ 7 July
What do you think? Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Just to be sure - that would be the version at the moment named 7.1 ?
Rainer
Martin Landa <landa.martin@gmail.com> writes:
bellow:
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
On 29/04/16 13:22, Martin Landa wrote:
bellow:
Should we maybe wait until we have released 7.0.4 ? Just to avoid too much work and confusion ?
Except for the overlap with 7.0.4, I think it's a good plan.
Moritz
2016-04-29 13:35 GMT+02:00 Rainer M Krug <Rainer@krugs.de>:
yes, Martin
Martin Landa
2016-04-29 14:14 GMT+02:00 Moritz Lennert <mlennert@club.worldonline.be>:
I am not sure how are these two issues related. Anyway GRASS 7.0.4
should be released within the text week too. Martin
Martin Landa
Just that it's generally the same people who create branches, write the announcement, etc and so I want to avoid overload
Moritz
On Fri, Apr 29, 2016 at 2:29 PM, Martin Landa <landa.martin@gmail.com> wrote:
Fully agreed with Martin - let's do that in parallel.
The 7.0.4 release is not much work (ok, several hours :p) especially
when this input comes from others:
- write a nice announcement blurb
- provide a catchy screenshot
I would be so happy to receive that!
2016-04-29 14:58 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
by creating a new branch I meant just creating a branch (one svn
command) and sending announcement to grass-dev ML. I can take
responsibility for that. Martin
Martin Landa
On Fri, Apr 29, 2016 at 7:22 AM, Martin Landa <landa.martin@gmail.com>
I have some things in lidar modules which would be good to do before the
branching, namely changing the layer options to flag(s) and removal of
vector output from r.in.lidar. Ideally, some code should go from modules to
the library but that might not be feasible in the given time frame (from my
side). The first week of May I can't promise any commits since I'm at
FOSS4G NA [1]
From things I remember, there is the prototype of Simple Python Editor
which needs a review but you (Martin) already did some, so I guess that's
fine.
[1]
https://grasswiki.osgeo.org/wiki/FOSS4G_NA_2016:_GRASS_related_workshops_and_presentations
On 29/04/16 15:07, Martin Landa wrote:
Ok, +1 from me, then.
Moritz
yes, Martin
Thanks.
I will than make a homebrew grass 7.2 formula as soon as the branch has
been created.
Rainer
Rainer M. Krug
PGP: 0x0F52F982
2016-04-29 15:09 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
side). The first week of May I can't promise any commits since I'm at FOSS4G
NA [1]
we can wait one week or so if you wish.
From things I remember, there is the prototype of Simple Python Editor which
needs a review but you (Martin) already did some, so I guess that's fine.
Yes, I used the editor in lessons. Nice tool! I had only one problem,
sometimes run button was not working (I discovered why after lesson
[1]
Ma
[1] https://trac.osgeo.org/grass/ticket/2997
Martin Landa
On Sat, Apr 30, 2016 at 8:09 AM, Martin Landa <landa.martin@gmail.com> wrote:
side). The first week of May I can’t promise any commits since I’m at FOSS4G
NA [1]
Thanks. This would give at least some chance to get things straight.
needs a review but you (Martin) already did some, so I guess that’s fine.
Thanks. It took me some time to discover that this is exactly what users want.
sometimes run button was not working (I discovered why after lesson)
I focused on getting the basics working but the executing is just tricky. Will try to look at it as well to see if some substantial changes are needed.
On Fri, Apr 29, 2016 at 1:22 PM, Martin Landa <landa.martin@gmail.com> wrote:
bellow:
I have added a new 7.2.0 milestone in trac (also a 7.3.0 milestone
which replaces the function of the actual 7.1.0 milestone).
We may now assign tickets to the 7.2.0 milestone from "7.1.0" to get
an overview what needs to be fixed for the next major stable release.
2016-05-01 9:35 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
probably we could rename dev version milestone as 7.1 / 7.3 since
these version will be never released (?) Ma
Martin Landa
On May 1, 2016 10:41 AM, “Martin Landa” <landa.martin@gmail.com> wrote:
Good idea!
Good idea!
Done as suggested:
milestone 7.1.0 renamed to 7.2.0:
https://trac.osgeo.org/grass/milestone/7.2.0
We have a an additional 7.3.0 (will never be released) which we will
rename to 7.4.0 in future.
All tickets not to be solved for 7.2.0 can be migrated to 7.3.0 now as
well as 8.0.0.
At time we have 155 open tickets on 7.2.0 which need to be reviewed
for that (or solved).
So, do we even need 7.3.0 milestone?
BTW, we need 7.0.4 version in Trac.
2016-05-10 15:23 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
it's already there [1]? Martin
[1] https://trac.osgeo.org/grass/admin/ticket/versions/7.0.4
Martin Landa
I agree to remove it.
On Tue, May 10, 2016 at 3:29 PM, Martin Landa <landa.martin@gmail.com> wrote:
I added it 15min ago and also update the release procedure document to
increment the version in trac to not forget again.
