[GRASS-dev] GRASS 7 add-ons on Mac OSX (10.9)
I try to install add-ons on GRASS GIS 7 beta on Mac OSX (10.9).
G7 has been installed including all frameworks from http://grassmac.wikidot.com/downloads
(snapshot from 11.08.2014, GRASS 7.0.0svn (r61585M)).
Now I’d like to install add-ons but neither the g.extension gui
nor running g.extension via command line works (tested with
2-3 extensions)
  1. via GUI:
g.extension --verbose extension=r.fuzzy.system svnurl=http://svn.osgeo.org/grass/grass-addons/grass7
Fetching <r.fuzzy.system> from GRASS-Addons SVN (be patient)…
A r.fuzzy.system/flood.map
A r.fuzzy.system/helpers.c
A r.fuzzy.system/local_proto.h
A r.fuzzy.system/flood.rul
A r.fuzzy.system/rule_parser.c
A r.fuzzy.system/main.c
A r.fuzzy.system/system.c
A r.fuzzy.system/f_result.png
A r.fuzzy.system/fuzzylogic.c
A r.fuzzy.system/io.c
A r.fuzzy.system/map_parser.c
A r.fuzzy.system/Makefile
A r.fuzzy.system/r.fuzzy.system.html
U r.fuzzy.system
Checked out revision 61649.
Compiling…
mkdir -p /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin
mkdir -p /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/etc/r.fuzzy.system
mkdir -p /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/docs/html
mkdir -p /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/docs/man/man1
test -d OBJ.x86_64-apple-darwin13.3.0 || mkdir -p OBJ.x86_64-apple-darwin13.3.0
gcc -I/usr/local/include -g -O2 -arch i386 -arch x86_64 -I/usr/local/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -DPACKAGE="“grassmods”" -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -o OBJ.x86_64-apple-darwin13.3.0/fuzzylogic.o -c fuzzylogic.c
gcc -I/usr/local/include -g -O2 -arch i386 -arch x86_64 -I/usr/local/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -DPACKAGE="“grassmods”" -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -o OBJ.x86_64-apple-darwin13.3.0/helpers.o -c helpers.c
gcc -I/usr/local/include -g -O2 -arch i386 -arch x86_64 -I/usr/local/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -DPACKAGE="“grassmods”" -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -o OBJ.x86_64-apple-darwin13.3.0/io.o -c io.c
gcc -I/usr/local/include -g -O2 -arch i386 -arch x86_64 -I/usr/local/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -DPACKAGE="“grassmods”" -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -o OBJ.x86_64-apple-darwin13.3.0/main.o -c main.c
gcc -I/usr/local/include -g -O2 -arch i386 -arch x86_64 -I/usr/local/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -DPACKAGE="“grassmods”" -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -o OBJ.x86_64-apple-darwin13.3.0/map_parser.o -c map_parser.c
gcc -I/usr/local/include -g -O2 -arch i386 -arch x86_64 -I/usr/local/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -DPACKAGE="“grassmods”" -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -o OBJ.x86_64-apple-darwin13.3.0/rule_parser.o -c rule_parser.c
gcc -I/usr/local/include -g -O2 -arch i386 -arch x86_64 -I/usr/local/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -DPACKAGE="“grassmods”" -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -o OBJ.x86_64-apple-darwin13.3.0/system.o -c system.c
system.c:122:11: warning: 7 enumeration values not handled
in switch: ‘t_START’, ‘t_IS_NOT’, ‘t_IS’… [-Wswitch]
switch (operator_stack[opr_top]) {
: && gcc -L/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib -L/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib -arch i386 -arch x86_64 -L/usr/local/lib -o /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin/r.fuzzy.system OBJ.x86_64-apple-darwin13.3.0/fuzzylogic.o OBJ.x86_64-apple-darwin13.3.0/helpers.o OBJ.x86_64-apple-darwin13.3.0/io.o OBJ.x86_64-apple-darwin13.3.0/main.o OBJ.x86_64-apple-darwin13.3.0/map_parser.o OBJ.x86_64-apple-darwin13.3.0/rule_parser.o OBJ.x86_64-apple-darwin13.3.0/system.o -lgrass_raster.7.0.0svn -lgrass_gis.7.0.0svn
1 warning generated.
/bin/sh: Radinger-2668/gisrc: No such file or directory
make: *** [r.fuzzy.system.tmp.html] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
if [ “/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin/r.fuzzy.system” != “” ] ; then GISRC=/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/grass7-Johannes Radinger-2668/gisrc GISBASE=/Applications/GRASS/GRASS-7.0.app/Contents/MacOS PATH=“/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts:$PATH” PYTHONPATH=“/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/python:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython:$PYTHONPATH” DYLD_LIBRARY_PATH=“/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Users/Johannes Radinger/Library/GRASS/7.0/Modules/lib:/Library/GRASS/7.0/Modules/lib” LC_ALL=C /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin/r.fuzzy.system --html-description < /dev/null | grep -v ‘|’ > r.fuzzy.system.tmp.html ; fi
rm r.fuzzy.system.tmp.html
  1. command line:
GRASS 7.0.0svn (Test_XY):~ > g.extension extension=r.fuzzy.system
Compiling…
system.c:122:11: warning: 7 enumeration values not handled in switch: ‘t_START’,
FEHLER: Compilation failed, sorry. Please check above error messages.
For other add-ons I get also error messages. E.g. for r.fidimo (python add-on)
I get:
GRASS 7.0.0svn (Test_XY):~ > g.extension extension=r.fidimo
Fetching <r.fidimo> from GRASS-Addons SVN (be patient)…
Compiling…
make: *** [r.fidimo.tmp.html] Error 1
Any suggestion. Do I need to install add-ons differently on a Mac, or
is this feature broken at the moment?
/Johannes
On Fri, Aug 15, 2014 at 11:07 AM, Johannes Radinger <
johannesradinger@gmail.com> wrote:
I tested r.fuzzy.system on Windows and Mac and it's working for me...
This part is weird:
Anna
Now I'd like to install add-ons but neither the g.extension gui
2-3 extensions)
1) via GUI:
Fetching <r.fuzzy.system> from GRASS-Addons SVN (be patient)...
U r.fuzzy.system
Compiling...
mkdir -p
mkdir -p
mkdir -p
mkdir -p
-DPACKAGE=\""grassmods"\"
in switch: 't_START', 't_IS_NOT', 't_IS'... [-Wswitch]
if [
"/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin/r.fuzzy.system"
!= "" ] ; then
Radinger-2668/gisrc
PATH="/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts:$PATH"
PYTHONPATH="/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/python:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython:$PYTHONPATH"
DYLD_LIBRARY_PATH="/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Users/Johannes
Radinger/Library/GRASS/7.0/Modules/lib:/Library/GRASS/7.0/Modules/lib"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
2) command line:
Compiling...
*system.c:122:11: **warning: **7 enumeration values not handled in
switch: 't_START',*
* 't_IS_NOT', 't_IS'... [-Wswitch]*
switch: 't_START',*
add-on)
I get:
Fetching <r.fidimo> from GRASS-Addons SVN (be patient)...
Compiling...
/Johannes
grass-dev mailing list
grass-dev@lists.osgeo.org
On Fri, Aug 15, 2014 at 5:56 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
<johannesradinger@gmail.com> wrote:
This part is weird:
It simply comes from the white space in the path (and above shows only
the second part):
if [ "/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin/r.fuzzy.system"
!= "" ] ; then GISRC=/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/grass7-Johannes
Radinger-2668/gisrc
--> "...Johannes Radinger..."
So some proper quoting will be missing.
>> Hi,
> This part is weird:
the second part):
if [
!= "" ] ; then
Radinger-2668/gisrc
Which needs to be corrected within "g.extension"? Or is there anything I
can do myself from a user's point?
Johannes
Has this issue with the white space in the path (“…some proper quoting will be missing.”) bin solved in recent versions of GRASS71? Both available binaries (http://grassmac.wikidot.com/downloads from Aug 14) for GRASS70 beta and GRASS71 show this problem. Just tested again with “v.surf.icw”:
g.extension --verbose extension=v.surf.icw operation=add
Fetching <v.surf.icw> from GRASS-Addons SVN (be patient)…
A v.surf.icw/v.surf.icw.html
A v.surf.icw/v.surf.icw.py
A v.surf.icw/Makefile
U v.surf.icw
Checked out revision 62038.
mkdir -p /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmp9I2sSx/v.surf.icw/bin
mkdir -p /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmp9I2sSx/v.surf.icw/etc/v.surf.icw
mkdir -p /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmp9I2sSx/v.surf.icw/docs/html
mkdir -p /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmp9I2sSx/v.surf.icw/docs/man/man1
mkdir -p /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmp9I2sSx/v.surf.icw/scripts
/usr/bin/install -c v.surf.icw.py /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmp9I2sSx/v.surf.icw/scripts/v.surf.icw
if [ “/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmp9I2sSx/v.surf.icw/scripts/v.surf.icw” != “” ] ; then GISRC=/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/grass7-Johannes Radinger-477/gisrc GISBASE=/Applications/GRASS/GRASS-7.0.app/Contents/MacOS PATH=“/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts:$PATH” PYTHONPATH=“/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/python:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython:$PYTHONPATH” DYLD_LIBRARY_PATH=“/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmp9I2sSx/v.surf.icw/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Users/Johannes Radinger/Library/GRASS/7.0/Modules/lib:/Library/GRASS/7.0/Modules/lib” LC_ALL=C /var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmp9I2sSx/v.surf.icw/scripts/v.surf.icw --html-description < /dev/null | grep -v ‘|’ > v.surf.icw.tmp.html ; fi
rm v.surf.icw.tmp.html
Compiling…
/bin/sh: Radinger-477/gisrc: No such file or directory
make: *** [v.surf.icw.tmp.html] Error 1
Is there any plan when new snapshots of GRASS71 are available on the grassmac platform?
/Johannes
On Fri, Aug 15, 2014 at 9:17 PM, Johannes Radinger <johannesradinger@gmail.com> wrote:
I tested r.fuzzy.system on Windows and Mac and it’s working for me…
This part is weird:
the second part):
Radinger-2668/gisrc
→ “…Johannes Radinger…”
Which needs to be corrected within “g.extension”? Or is there anything I can do myself from a user’s point?
Johannes
On Sat, Sep 20, 2014 at 1:04 PM, Johannes Radinger
Has this issue with the white space in the path ("...some proper quoting
will be missing.") bin solved in recent versions of GRASS71? Both available
beta and GRASS71 show this problem. Just tested again with "v.surf.icw":
if [
!= "" ] ; then
Radinger-2668/gisrc
Wild guess: scripts/g.extension./g.extension.py line 757 ff:
    makeCmd = ['make',
               'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
               'RUN_GISRC=%s' % os.environ['GISRC'],
               'BIN=%s' % dirs['bin'],
               'HTMLDIR=%s' % dirs['html'],
               'RESTDIR=%s' % dirs['rest'],
               'MANDIR=%s' % dirs['man'],
               'SCRIPTDIR=%s' % dirs['script'],
               'STRINGDIR=%s' % dirs['string'],
               'ETC=%s' % os.path.join(dirs['etc'], name)
    installCmd = ['make',
                  'MODULE_TOPDIR=%s' % gisbase,
                  'ARCH_DISTDIR=%s' % os.path.join(TMPDIR, name),
                  'INST_DIR=%s' % options['prefix'],
                  'install'
Does this have anything to do with
https://docs.python.org/2/library/subprocess.html#frequently-used-arguments
"When using shell=True, pipes.quote() can be used to properly escape
whitespace and shell metacharacters in strings that are going to be
used to construct shell commands."
