I just compiled GRASS 7 Trunk.
It crashes on startup with the following error:
GRASS 7.0.svn (nc_spm_08):~ > Traceback (most recent call last):
File “/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py”, line 140, in
sys.exit(main())
File “/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py”, line 133, in main
app = GMApp(workspaceFile)
File “/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py”, line 45, in init
wx.App.init(self, False)
File “/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py”, line 7981, in init
self._BootstrapApp()
File “/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py”, line 7555, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py”, line 79, in OnInit
workspace = self.workspaceFile)
File “/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py”, line 106, in init
self._menuTreeBuilder = LayerManagerMenuData()
File “/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/menudata.py”, line 31, in init
MenuTreeModelBuilder.init(self, filename)
File “/Users/Shared/grass_dev/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/menutree.py”, line 61, in init
xmlTree = etree.parse(filename)
File “/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/xml/etree/ElementTree.py”, line 862, in parse
tree.parse(source, parser)
File “/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/xml/etree/ElementTree.py”, line 587, in parse
self._root = parser.close()
File “/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/xml/etree/ElementTree.py”, line 1254, in close
self._parser.Parse(“”, 1) # end of data
xml.parsers.expat.ExpatError: no element found: line 1, column 0
No changes on my end since compiling it without a problem a week ago.
Michael
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
