currently no way to start GRASS as I am used to do:
grass70 ~/grassdata/spearfish60/neteler/
Cleaning up temporary files ...
Starting GRASS ...
GISDBASE, LOCATION_NAME and MAPSET variables not set properly.
Interactive startup needed.
Could the CMD line startup added again? I am not much inclined to set
three variables manually when the shell history remembers so nicely
previous calls (CTRL-R <few chars> in bash!).
then you can type a few letters and use PgUp, PgDn instead of Bash's
less friendly ctrl-r way. Anyway for me it is much nicer to use and I
can't understand why user focused distros don't set that up by default.
OT tip2: more signal by not recording duplicates in .history file:
export HISTCONTROL=ignoredups
