[GRASS-dev] Grass add-ons and binary grass version
I made a script for grass, wich is now on the add-on repository
http://grass.osgeo.org/wiki/GRASS_AddOns o https://svn.osgeo.org/grass/grass-addons/raster/r.inund.fluv/
With the makefile is possible install a grass-addon if a user installed grass from a binary?
I tried, but I’m not expert!
If isn’t possible I think that a little script install.sh may be useful for a lot of users.
I made it, but maybe this script can has some problems for his portability.
I may add this script with a good explanation in the readme file? What do you think?
Thanks in advanced.
Roberto
repository
I tried, but I'm not expert!
For C modules which need to be compiled at the user end the way to do that is with the "GEM",
http://grass.osgeo.org/grass63/manuals/html63_user/gem/index.html
For shell scripts make sure all executables are in some directory (and each has the executable bit set). Set the GRASS_ADDON_PATH environment variable to that path before starting GRASS and it should be able to see & run them.
I think for fortran just make sure that stand-alone executables wind up in the GRASS_ADDON_PATH with the shell script. I don't know about how well GEM supports that currently. (??) If the fortran code needs to reference the GRASS headers when it is compiled by the user, it will probably have to either be compiled with a full source build of GRASS or take advantage of the GEM files.
Hamish
ps- please use descriptive svn commit messages.
