[GRASS-dev] GRASS and GDAL 1.4.1 MingW
Any reason not to add your archeology modules to the set of grass addons?
---- Original message ----
Date: Fri, 15 Jun 2007 14:08:56 +0200
From: Benjamin Ducke <benjamin.ducke@ufg.uni-kiel.de>
Subject: Re: [GRASS-dev] GRASS and GDAL 1.4.1 MingW
Cc: GRASS devel <grass-dev@grass.itc.it>
Two reasons:
a) I want to be sure that I understand all details involved in the
compile process under MingW
b) I have a lot of custom code that I need to merge into the current
CVS tree and compile along with it, as GEM does not yet run w/o problems
with the MSYS based version of GRASS
... my ultimate goal is to create a version of the current CVS of GRASS
6.3 for use in archaeology. This will include all the additional modules
I have written for GRASS over the years.
But I will also keep testing your CVS packages as time allows.
Benjamin
Moritz Lennert wrote:
On 12/06/07 12:35, Benjamin Ducke wrote:
concerning the troubles with the DBF driver under Win32 that I wrote
about earlier, I am trying to compile a current version of GRASS
with MingW.
Just out of curiosity: any reason you do not wish to use the precompiled
version available at:
http://moritz.homelinux.org/grass/wingrass/
I try to be more or less regular in providing packages based on the
latest CVS (although the latest one is ten days old...I'll put up a new
one tonight or tomorrow).
Moritz
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
grass-dev mailing list
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
It's pretty complex code with additional external dependencies and most
of my archaeological colleagues simply don't have the technical know how
to get it running from a source repository.
This was the original reason why I created GEM which now comes with the
current GRASS in CVS. Since I don't have the time to maintain my code
in several repositories, I will maintain it only in GEM packages.
In the near future, I want to make these work on MingW, as well, but for
now I need a quicker solution because I want to use the software in a
class this semester.
Two reasons:
Benjamin
with MingW.
Moritz
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
Gerald Nelson
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
