[GRASS-dev] [grass-code I][422] v.transform pointsfile does not accept points in dd:mm:ss format
code I item #422, was opened at 2007-06-11 15:09
Status: Open
Priority: 3
Submitted By: Harri Kiiskinen (harrikoo)
Assigned to: Nobody (None)
Summary: v.transform pointsfile does not accept points in dd:mm:ss format
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: vector
Operating system: Linux
Operating system version: Debian 4.0
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
v.transform does not accept point coordinated given as dd:mm:ss.ss in the 'pointsfile' option. If the coordinates are changed into decimal, everything works ok.
Harri K.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=422&group_id=21
This is a duplicate of Harri's ticket sumbitted on 07.06.2007. Deleted
from tracker.
Maciek
