#1081: "Attribute Table Manager" not show data and v.extract doesn't work
Reporter: zarch | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
Hello,
I have a big vector table (with areas) with 22604 rows and more than 100
columns. I'm using grass-trunk 42416 on 64bit Linux system.
If I try to visualise the attributes with "Attribute Table Manager"
grass70 doesn't
work with both case using 'dbf' and 'pg' driver.
Instead if I try to make a query from "Map Display" or if I try to use
v.db.select they
work properly.
The "Attribute Table Manager" works fine with other small vector map (with
Line
and Polyline).
Moreover I get this error:
> v.extract --overwrite input=fustaia output=try01 \
where='accifus=1 AND ripresa>0'
ERROR: Database connection not defined for layer <-1>
This is my actually db connection:
> v.db.connect -g map=fustaia
1/public.fustaia|public.fustaia|cat|grassdb|pg
With grass64r5 the command v.extract and the window "Attribute Table
Manager"
work fine.
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by martinl):
Replying to [ticket:1081 zarch]:
grass70 doesn't
What do you mean by "doesn't work"? Any error message, or so? BTW ATM
needs some optimalization for larger tables, it can be very slow.
Resolution: | Keywords: v.extract
Comment (by zarch):
Replying to [comment:1 martinl]:
100
grass70 doesn't
I mean that no any attributes it's shown (I wait for 10 minuts) with
grass64 to see the same table, I need more or less about 1 minut.
> Should be fixed in r42420.
yes, now it's working! thank's
Reporter: zarch | Owner: grass-dev@…
Type: defect | Status: closed
Resolution: fixed | Keywords: v.extract
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:3 zarch]:
100
grass70 doesn't
